Results 1 to 10 of 11
Thread: Can I paint my earthmate?
    Apr 2003
    Would it hurt my earthmate if I took a can of flat spray paint and painted it from that stickout yellow to maybe black or grey?
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Makes sure there is no metal in the paint. If should be fine.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    May 2004
    NJ
    I would recomend if you remove the cover first, you don't want any thing inside the housing.
    Apr 2003
    Thanks for the quick response. I'll take the top off and give it a once over.
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Try to track down some vinyl dye, it's a spray that permanently dyes plastics. You'll probably have to dye it white first, and then whatever color you want. Or black. It has the advantage of not scratching off like regular paint (which just adheres to the surface) will.
    Apr 2003
    About how much does this cost?
    I mean if it's expensive. I'll just use the $1 spray paint and touch it up every so often..Call me cheap
    Aug 2004
    California
    Sticking with the $1 paint you've got would be best then, this stuff runs about $7/can.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    You could dip it in plastidip & make it waterproof too
    Apr 2003
    $7 a can ouch that is steep. Would have to find a ton of other stuff to dye to make it worth it...
    Hayling Island, UK
    vinyl die is the best, i have a can of mat black. used it to paint a cd-rom drive and the case of a pc. still loads left.
    Best thing to do when spraypainting is light coat, lots of times. not one big coat of paint.
  1. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 11:44 AM
  2. Replies: 21
    Last Post: 06-30-2004, 02:17 AM
  3. Paint type
    By LittleDragon in forum Fabrication
    Last Post: 04-24-2004, 06:35 PM
  4. Car Paint Repair Question
    By Max018 in forum Off Topic
    Last Post: 03-12-2004, 01:03 PM
  5. Replies: 5
    Last Post: 01-04-2004, 10:43 PM
