Results 1 to 6 of 6
Thread: to all with handheld GPS mounts
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Hey, I made this unit because I wanted a better way then having to plug the cable into my GPS reciever everytime I got in the car and I didn't want to leave it in the car all the time. It is a radio shack suction Cell Phone Holder that was on sale for $9.99 I drilled a hole for the back with a dremel, cut the back of the casing so that the pfranc connector could fit thru, made a cable using the pfrac connector and then assembeled everything together. I had problems with my first cable, it came loose and the computer kept losing signal, I just redid the cable, and it seems to work alot better then before. Any way here are the pictures, if you would like more pictures or information let me know. I was going to make a how-to but its pretty self explanatory. btw the GPS reciever is an oldschool garmin GPS 12 and it uses the 5 pin garmin connector.
    - edit Wow sorry about the bad pictures, they came from an intel cam I won, will submit more pictures as there is a lack of them
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Nov 2003
    NC
    Any coments/questions on this? I want to hear feedback!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I like it, mine is setup almost the same way except I used a GPS 48 which has a BNC plug for the antenna so I could reroute the antenna to a better place
    Nov 2003
    NC
    Did you have any problems with GPS timing out?? Im having problems at the moment, I think its because the pins arn't long enough to go thru the extra plastic. it works untill you close it, which is a pain because you can't operate it with it open... I wouldn't mind an external antenna for mine... maybe they have a mod for it :-P
    May 2003
    Miami, FL
    no none, but I did change the connecter to a dsub I didnt want to spend the money on the combo data/power cable. I pulled my gps 12 apart thinking the same thing. I added a antenna on a foot long high grade coax and it made it worse, I dont think the reception circuts are very good in it. because I used the same cable and antenna for my 48 and it improved greatly. But I think after all this I am going to the gps76 which my friend has and it locks in like 5 secs warm
    Nov 2003
    NC
    I don't have a problem with my 12 really, it just takes a minute to lock. The problem im having is my cable not making a good connection. Guess I will ripp it apart again and see if I can fix it. Im making my data/power cable, but I have to get the data part working first :-P you can buy the plugs from pfranc.com I got 3 plugs for $15 shipped. Its a great service.
  1. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 03:24 PM
  2. FS: GlobalSat bluetooth GPS receiver and Street Atlas 2004 handheld
    By chiefsalami in forum Classified Archive
    Last Post: 09-02-2004, 01:40 AM
  3. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  4. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
  5. Using a handheld GPS with a carputer?
    By commodore_dude in forum GPS
    Last Post: 05-19-2004, 07:49 PM
