Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 104
Thread: programming deadreckoning gps software?
    May 2004
    Hi,
    I read an article about the new tomtom-go device, which uses some sort of software-based deadreckoning system, in case it looses its fix.
    I think it wouldn't be too difficult to program something like that for the pc, but I don't have enough programming experience to do so...
    Basically the software should do this:
    - input the standard NMEA sentence of the GPS using a com-port
    - check if the fix is lost (in case of a tunnel)
    - in case the fix is lost : continue to send computed NMEA data, based on the last known position, in combination with speed and heading
    - output the NMEA data to a (virtual) comport, feeding navigation software
    Then you would be able to still have a (virtual) fix, even when you suddenly lose the fix, caused by bad skyview (tunnels etc)
    I hope anyone can program such a little piece of software???
    Jun 2004
    Sydney, Australia
    I saw someone talking about this in another thread. I think it should go one step further. Use a Gyro/Compass to determine whether you are turning, speed sensor to detect change in speed, etc. It could almost be done in Hardware (more difficult, but easier to integrate with speed sensors etc). This is quite a cool idea i think!
    Jun 2004
    Sydney, Australia
    Further thinking, this could be done in code, as long as:
    a) You could create a virtual Com port which you can point the GPS Software to
    b) You have a way of getting Vehicle Speed/Direction INTO the computer
    Now the following is just pseudocode dribble, but it might help someone who can work out how to achieve the 2 points above:
    Code:
    Variable Descriptions:
    X=Coordinate (the further north you go = the lower the x coordinate; is this how GPS coordinates work? If not, then some of the calculations below might need changing)
    Y=Coordinate
    V=Velocity (MS)
    D=Direction (0-359 degrees)
    Timer=500Ms (User Settable)
    Sample Pseudocode:
    Main.Initialize
        'Get starting coordinates. If no lock is present, read last known coordinates from file
        If Not ReadGPSNMEAString() Then
    	ReadLastCoordinatesFromfile()
        EndIf
    End Main.Initialize
    Event Timer.Tick
        If ReadGPSNMEAString() Then  'GPS Lock exists
    	'Bypass coordinate calculations
    	TransmitNewGPSData()
        	WriteCoodinatesToFile() 'Always write last coordinates to file - incase user shuts down at this point
        Else  'No Lock exists
    	'Process last known Speed/Direction values
    	Select Case D '(Direction)
    		Case 0:
    			X=X-(V*(1000/Timer))
    		Case 90:
    			Y=Y+(V*(1000/Timer))
    		Case 180:
    			X=X+(V*(1000/Timer))
    		Case 270:
    			Y=Y-(V*(1000/Timer))
    		Case Else:
    			DeltaX=Sin(D) * (V*(1000/Timer))
    			DeltaY=Cos(D) * (V*(1000/Timer))
    			X=X-DeltaX
    			Y=Y-DeltaY
    	End Select
    	'Send new coordinates to fake com port
    	WriteCoordinatesToFile() 'Always write last coordinates to file - incase user shuts down at this point
    	'Get New Speed/Direction coordinates (this is assumed to be the vehicle's direction for until the next timer tick)
    	V=GetVehicleSpeed()
    	D=GetDirection
        End If
    End Event
    Procedure ReadGPSNMEAString()
    	'Get X & Y Coordinates
    	'Calculate velocity and Direction
    End Procedure
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    The virtual COM port is easy enough.
    This one... well, the one at the bottom, can take input from one port and send it to a few others. All you would need to do is read from the GPS, process it, and write it to this one.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Curiosity
    Dude, when I click 'install service' I get 'unable to find xport.sys' message box. Tried xport.sys in same dir and in path! Could be my desktop pc of course, I'll try it on another....
    Edit: S'ok, it's my desktop! I'll try it in the car.
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    I've been considering doing something like this for awhile. I used to write the software for aircraft navigation systems for the Navy, so the dead-reckoning equations are not too difficult. The problems are getting an independent source of speed and heading, and feeding the resulting DR position in the form of NMEA statements back to the comm port, to be read by the regular mapping software.
    I think this dual axis accelerometer phidget would be able to supply the speed and heading.
    I have contacted the author of the GPSGate program, to see if he could add the capability to intercept and process the NMEA stream prior to sending it out the virtual port. He just recently added an SDK, but not sure yet if it can do this so I'm going to look into it.
    One other thing that this software should have, is to be able to generate a fix position that could be used to compute position corrections, that could then be applied to the GPS position. Then you could mark on top a known lat/long and compare to the GPS position and compute lat and long corrections. These would be applied to all subsequent NMEA positions before sending on to the mapping program.
    Raw Wave
    Jun 2003
    The TomTom Go doesnt use a standard gyro but instead it does use a dual-axis accelerometer to calculate speed, heading and acceleration...etc.
    The accelerometer module only supply the forward-backward and lateral g's (I have the ADXL202 module used for measuring g's in the car). This work fine on flat roads for measuring g's but the problem is when the car is driven hard it will tilt naturally and therefore give a wrong g reading, you will get more g...unless the tilt g is substracted.
    Applying this for GPS use, the software need to do some calculation such that it doesnt think that the car is accelerating when the GPS looses its signal on a hill...but how can it know as I dont think TomTom Go need any other connection to the car
    If someone can work out how the accelerometer is used in the TomTom Go then a PIC MCU can be used to take over the calculation. The PIC get the NMEA data from the GPS, calculate the values read from the accelerometer and spit out the computed locations whenever the gps looses its signal. This way its going to be an add-on hardware module for the gps making it compatible with any gps software. No need for an extra serial port for the accelerometer or an additional software to compute the NMEA sentence and the accelerometer values and no need for a virtual comport to combine the 2 values into one port.
    Maybe someone here can reverse engineer the TomTom to see whats going on.
    GPS + Accelerometer + PIC = sounds like an interesting project
    Jun 2003
    Chester Springs, PA
    I think you would just need to put another accelerometer in the third axis to sense pitch (up-down), since the dual axis accelerometers would be sensing forward-back and left-right.
    Either that or rig up something like a bubble level to know when the car is going up a hill. Maybe with the rotation sensor phidget and a weight?
    Raw Wave
    Jun 2003
    From TomTom Go review :
    TomTom Go has a two plane acceleration sensor with no moving parts unlike conventional gyro systems. The sensor will be good enough for several hundred meters so TomTom Go can continue to work when GPS signals are not available (for example in tunnels with exits).
    It does say no moving parts and only use a dual axis accelerometer, the rest must be softwares...the TomTom guys must have done it somehow.
    Constant Bitrate jpelzer's Avatar
    May 2004
    NYC
    It's not really that complicated... Most tunnels are straight, and hopefully not too many turns before gps lock is reestablished. I don't think you need to take into account tilt at all, but I think you WOULD need to calibrate the system based on incoming GPS date when it was first installed.
    Depending on where the accelerometer was installed on the car (front to back), your G's would be different, and this would be more apparent for lower-speed (short radius), and negligable for large radius (highway speed) turns.
    So you'd need to track a turn while the GPS was locked, and then correlate that to the measured G's.
    I already ordered that Phidget accelerometer, for just this project. Damn you guys for beating me to post! I think it will be perfect for our application, as it has a VERY simple SDK for communicating with it. And it's only $50.
    As soon as we have source for creating virtual com ports, we're there. NMEA shouldn't be a tough nut to crack.
    Bush: Proof that humans really did evolve from apes.
  1. Wtb: Gps Software And Gps Mouse!!!!
    By HitmanZ in forum Classified Archive
    Last Post: 08-03-2004, 10:56 PM
  2. CoPilot Software or USB GPS Receiver package
    By Zip-Lock in forum Classified Archive
    Last Post: 05-13-2004, 08:30 AM
  3. Replies: 2
    Last Post: 01-06-2004, 10:19 PM
  4. GPS software
    By waylonh in forum Input Devices
    Last Post: 11-25-2003, 07:48 AM
