Results 1 to 10 of 10
Thread: All in one GSM/FM/GPS Antenna
    Raw Wave
    Jun 2003
    Probably posted before...
    Those whos having problem with GPS receptions/stealth install check this out :
    http://www.tdc.co.uk/antennas/antenna_gpsgsm.htm
    Maplins also list them in their latest catalogue...not on their website yet.
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    um..can gps be usb for these
    DICE Los Angeles
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    http://www.tessco.com
    Excellent supplier of antennas and mounts and such. You have to know what you're looking for, though.
    New York
    Awesome find and just brings in more questions. First, I guess you were talking about the AE 536?
    Anyways, I see this is a UK Site so I am woundering about the AM/FM frequency portability to the US. I think they're the same, but I don't know the exact specs.
    Ricky - Would you happen to now the GPS functionality is just a Gain Receiver antenna that still needs to be plugged into a GPS Receiver gevice or can this signal be used directly to the computer?
    Raw Wave
    Jun 2003
    Quote Originally Posted by DaRacerz
    Yes one of the AE antenna...infact most of the antenna there should help those whos having problem with GPS signals. But I think I like the AE so I can just replace the standard antenna in the car rather than having to drill a hole on the roof.
    Not sure if the FM/AM frequency range are the same with the UK and US. It does say the frequency range it can covers so I guess it just a matter of checking this with the US FM/AM frequency.
    You need a GPS receiver with an external antenna connector to be able to use this antenna. It just an antenna no GPS receiver built in.
    If the receiver have external antenna socket yes.
    I havent use one of this antenna (just passing on the message) but I think its cool having one in a car rather than placing the GPS on top of the dash...it will get stolen as well having to put up with poor signal.
    The antenna similiar to the AE cost £80 in maplin :
    www.maplin.co.uk
    Dec 2003
    St Albans, Herts, UK.
    Those in europe may also like to check-out these people in Belgium http://www.carcomm.nl/
    Take a look under GPS (Combined WiFi/GPS/Tri-Band GSM !) and under Special Antennas they have a GPS/AM/FM/Tri-Band GSM, but sadly no price.
    Kevin
    Oct 2003
    do u know if exist a
    AM/FM/UHF/VHF/DAB antenna?
    AM/FM/UHF/VHF/DAB/GPS antenna?
    ptk
    ptk is offline
    Singapore
    Quote Originally Posted by Denun
    looking for just such a beast
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Can these external applified GPS arials be used with a Globalsat BU-303, I know it would need mods but can it be done by someone with average soldering/electrical abilities or would we need to be 'electronics experts'?
    John
    Raw Wave
    Jun 2003
    You may find that the BU-303 uses an OEM bare sensor. If you can see a sensor and an antenna in one casing then maybe it has a cable to connect the two with the connectors.
    I may open up my Garmin GPS16 and hopeuly Ill find something like :
    http://www.garmin.com/products/gps25/
    or
    http://www.garmin.com/products/gps15/
  1. Tall Wifi Antenna
    By EBFoxbat in forum Wireless Communications
    Last Post: 11-22-2005, 07:43 PM
  2. F/S: Linksys Wireless G USB Receiver with moded Antenna
    By LESLIEx317537 in forum Classified Archive
    Last Post: 11-19-2005, 08:56 PM
  3. any one used the Terk TV55 Antenna
    By lawrence in forum General Hardware Discussion
    Last Post: 08-31-2004, 08:06 PM
  4. Any way to use your car's antenna as a WiFi antenna?
    By NoNonsense in forum Wireless Communications
    Last Post: 07-17-2004, 10:34 AM
  5. wardriving antenna
    By wizardPC in forum General Hardware Discussion
    Last Post: 01-20-2004, 12:25 AM
