Results 1 to 6 of 6
Thread: Triggering events based on GPS location
    Central NY
    I am in the process of building my car pc, and I would like to include GPS navigation using one of the better software packages out there. However, I also would like to run a certain exe or macro whenever I am within a short distance from my house, while getting close.
    The only way to do this would be by looking at the GPS data and see where I am and see if I am leaving or approaching the house. Is this something some GPS software can do already? If not, would I be forced to chose between GPS nav and that functionality (I will write my own software) or can most GPS units be shared between the several software packages running? Thanks!
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    I would imagine, if you can program, which I can not, that you could take the data stream from the GPS and have it trigger events based on location etc. I don't think it would be all that hard.
    I think the issue is that if you are using the GPS data for your own little app, then u can't use it for traditional GPS apps
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    I'm sure it'll be pretty simple to get something like this into AIMEE
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Have a look at EvetS, google 'EvetS' and 'Speedcam'. IIRC This is a VB based program that triggers a sequence of Wav files when approaching a GATSO camera's GPS location... Maybe you could use this in some way, add your house as the only GPS location in a database and have it run a batch program or something...
    The guy who wrote this app is known as Goto10 on this forum... He maybe able to help you.
    John
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Quote Originally Posted by EBFoxbat
    A port splitter like GPSGate can create multiple virtual ports that can each feed a NMEA data stream to separate apps. I've already had MapPoint, Routis and my own little GPS app running at the same time.
    Central NY
    wow, very nice find! This is exactly what I am looking for.
  1. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 03:51 PM
  2. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
  3. GPS Based Security System
    By chewiee in forum GPS
    Last Post: 04-29-2004, 01:59 PM
  4. Photo based GPS navigation ?
    By felix99 in forum GPS
    Last Post: 03-02-2004, 02:28 PM
  5. GPS location ?
    By cvi in forum MediaCar
    Last Post: 11-21-2003, 07:23 PM
