Did you copy his data from the CD into your hard disk? He doesn't need an ISO file, does he?
I installed Street Atlas 2003 and his data CD, but when I start the program he ask me if to start without the data. I try to browse and point to the data directory but no luck. any idea?
I don't understand who is he? When I used street atlas 03 I just did both cds and it started up fine.
Mine needs to be updated.
I have 2004 and needed to make a registry change to tell it to look on C rather than D for data:
http://www.delorme.com/support/stree...=&P=55114&C=28
Budman
Xenarc PC, dual 7" touchscreens, 512mb, 20g, dvd, Earthmate GPS, Keyspan remote control, voice control for media, 8-in-1 card reader, Bluetooth Razr, 54mbps 802.11g wireless.
Honda Element Carputer
I run it on Win95 without CD-Rom (I use Virtual CD-ROM). The GPS work great but I cann`t see the map, **** :-)
Originally Posted by omer72
I'm almost certain that you don't need to make a virtual CD drive. Just copy the data CD into a hard disk directory.
Street Atlas 2003 comes with a utility to allow you to copy the data drive to the hard drive. Instructions to run it are either in the help system, or Delormes website.
Ted
but still no luck. Maybe there is a way to load the maps after the program start?
the instructions are in the net tab
click on the net tab > scroll down and follow the instructions
or just copy the cd data disk to a drectory that you name SA2003
when you start program choose- to run from that directory
i have been doing this since ver 5.0
Hey the way to not use the cd to view the maps in Street Atlas is: Put in the cd (the one you use to view maps, not the install one) and then run the setup.exe on it. It will automatically install itself onto the hard drive and you are free to use the software without the 2nd cd!! Enjoy!
