Thanks! I thought i was the only one who couldnt afford a VGA touch screen! And either way, the bigger the text the better anyway - you dont want to have to concentrate to read the text while driving!!!
Can't wait to try this out![]()
Ok i have a 7" LCD that uses composite and of course mp3 and videos are great but when the GPS comes into ply its just way to small to use basiclly.
So what i did was do alot of testing in the car to make the LCD read Destinator on the LCD easily
So what i did was go to C:\PowerLOC\Destinator\Common\Interface\Destinator .Inf and open up the file in notepad
Now move down to neer the end of the file and u will see
::F,Tahoma,24,0
I changed it to ::F,Arial,35,0
Now this the text size of the text in the GPS setting windows so u can see what comport etc you are selecting. It also changed the text in the settings window and the text on the bottom right showing how many sattelites there are.
now right at the start of the file u will see
SIZE=24
change it to 35 or the setting you best want.
This changed the size of most items mostly the button sizes
Now under that you will see these
::T,ABOUT,200,LF,,,24,About
::T,ADDRESS_BOOK,200,LF,,,24,Favourites
thats the size of the text for the buttons like about favourites etc
change the 24 to 35 or a size that suits you
Also note that cause im in australia this was annoying to me:
::T,CITY_STREET,200,LF,,,24,City->Street
Now in australia we dont call it City so i changed it to
::T,CITY_STREET,200,LF,,,24,Suburb->Street
same with
::T,STREET_ZIP_CODE,200,LF,,,24,St.->Zip
We call the Zip code postcode in australia so i changed it to:
::T,STREET_ZIP_CODE,200,LF,,,24,St.->P. Code
makes sense
Now scroll down till u see something like this:
//:,240,320,639
:,640,420,640
now i changed the last line to 640 instead of 639
This means at 640 the onscreen keyboard will showup when u search for a street.
Now onto the Sound for destinator
Some people say they can't hear the voice directions over the mp3's play sometimes.
Well what i do is open up the Sound recorder in Start > Programs > Accessories > Entertainment
and i open up the wave files from destinator then i just click the effects button then click increase volume by 25% till you think your happy with it then save it.
Now you can view and hear destinator perfectly
Only problem is the map you cant change the text size of the citys/suburbs but you dont need to bother about it cause i use 3d mode a bit but i also use normal mode and if u wanna know what street your on click the info button for it to tell u as he text is now readable for u
I hope this helps some people till the D3 sdk gets sorted out![]()
Also you could do what iv done and actually changed the button bmp files to match the media car skin
Im also working on a nice media car skin that looks good on a composite LCDas i dont want to pay $500 for a lilput
Hope this helps some of you guys who are stuck with destinator till we get a new version and i hope it helps make life easier for guys without a VGA screen like me![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
You can make it all look great the only problem on a composite LCD after your edit it to how u like it the only problem y have on the LCD is not readin what street you are in and clicking the info button will tell you thats the only problemthe text on the maps is actually on the map so u can't change the size i dont think.
Im just glad i help atleast 1 person![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
You try to use the buttons that I have done me for D2 SDK .
I had drawn ago them a few months to use with the skin of Mediacar " Brusheed metal" and they are liked a lot.
You replace the original file in C:\Powerloc\Destinator\Common\Interface with my file.
You make to know if you like![]()
Mauri
I might as well post mine 2
Iv changed to a newer type its a kind of aqua look but im still working on it
these look nice but they match the skin i orignal made so you prob wont want it
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Its OK also your buttons, however' as they are mine they have a lot of effect 3D inthe Dest2 menu.
Your buttons seem proper for the new alpha version of Dest3 SDK.
We hope that there am also soon an update with the active buttons in the menu of Dest3![]()
Mauri
i "should" have my screen on monday (not a vga) so ill be give this a try
thanks
Nah im sure someone else can make better buttons for the new D3 SDK i just waiting for a respone i want it so badOriginally Posted by mauri
hehe
Thoese buttons are from when i was making my own frontend as i dont need the DVD player and also i was addin a special button so if a cop ask me to play divx from the main menu it will say you are not allowed to watch video files while the engine is on just to be safe
but i ran into a snag with winamp playlist and directorys so im just using media car now.
Im also gonna add SCANLINES to the orignal media car skin to see if it helps it look better on the LCD it should![]()
What Type of screen? 7" or 5" ?Originally Posted by TX5
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
just got it
its a 7"
Post pics post pics![]()
My 7" LCD is a unipac its OEM so i need to make a case and everything for it as its just a LCD and controller board no case![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
