Try putting it ontop of a metal object etc. i dont know how u can improve it besides tin foil???I had a prob earlier with gettin a lock, and thats resolved (sorta)
Try changing the com port in device properties as u could have a conflicting port being used.and i always seem to get 'GPS not found'. Yet, I can see the red light on (no lock). its set to the right com port, being com port 3
Have u tryed doing the auto search in destinator should still be in d3.1 SDK
It's not ment to stay ticked after you click it WASS is used if the GPS supports it so destinator will use WASS if the gps supports that feature u dont turn it on or off.O and when i use the GPS info utility to select Waas, it never stays checked after i reopen the program
Hope this has helped you some bit![]()
LinkBack URL
About LinkBacks
You can check it in Device Manager, it should appear as another com port - not as a
