Results 11 to 20 of 24
Thread: Dual GPS receiver ?
  1. #11
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    the only thing I think would be worth doing would be, if you are writing your own GPS application (or D3 interface, or a 'third GPS com port device') would be to monitor both, and output the reading of the one with the best lock - and if the other one goes tit's up, sending the required reset commands.
    Otherwise it's a lot of work for not much improvement
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  2. #12
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    What would make a difference is putting one at the windshield and another at the back window. That way, the complete sky would be "visible" and locks would be to different sats.
    Joa
  3. #13
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Good thinking, batman!
    I'm going to grab my GPS receiver, and along with Danceheaven's, i'll see if i can figure anything out
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  4. #14
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Confused
    Garry
    Sounds kinky
  5. #15
    Raw Wave
    Jun 2003
    You are better off buying an external antenna (if your GPS have the connector for it) :
    http://www.maplin.co.uk/Module.aspx?...dID=&doy=14m10
    Placing 2 GPS one at the back and at the front will only give you like the average position in the middle. If the signal are weak in the area both GPS wont be accurate anyway.
    Its probably worth a try if you got access to 2 GPS and the program to average out the position.
  6. #16
    Aug 2003
    Essex, England
    Quote Originally Posted by Enforcer
    Sounds kinky
    Well, anyway, i'm going to give it a try tonight, will report back with findings
    Garry
    www.aimee.cc
  7. #17
    Aug 2003
    You might take a page from aircraft navigation systems, they will often use 3 sensors.
    If all closely agree, great, average the results.
    If 2 closely agree, and one is having a bad moment and thinks youre in Buffalo, then disregard the bad sensor input.
    May do away with the annoying display that you're off roading as you head down the interstate?
    Best, RC
  8. #18
    Raw Wave
    Jun 2003
    Having multiple GPS receiver is beneficial but I "think" the importance goes in this order :
    Have a better receptions, the dead reckoning and then multiple receiver. Whats the point in having 10 receiver inside the car when non of them can give direction under a carpark, city etc?
    @ Confused, any luck on your experiments?
  9. #19
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    IMHO,
    1. good receiption (quality ant& amp)
    2. Gyro for dead reconing through short periods of GPS sig.loss
    3. Good map software(quick sample times) that's quick to react to missed turns
    After that, I'm not certain the built-in inaccuracy for 'comercial' GPS will ever be overcome by multiple antennas.
    Millitary GPS has greater accuracy..but that technology isn't publicly available.
    •Micke
  10. #20
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Sounds like the most expensive way to roughly calculate the length of your vehicle I've come across
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  2. what to look for in a GPS receiver?
    By doublestack in forum GPS
    Last Post: 10-01-2004, 04:05 PM
  3. Dual GPS Rcvr's. Unusual thought...
    By d_sellers1 in forum GPS
    Last Post: 06-21-2004, 08:26 PM
  4. CoPilot Software or USB GPS Receiver package
    By Zip-Lock in forum Classified Archive
    Last Post: 05-13-2004, 08:30 AM
  5. $69 12 channel GPS receiver - anyone tried this one?
    By LCDcrazy in forum General Hardware Discussion
    Last Post: 09-05-2001, 01:50 PM
