Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Dual GPS receiver ?
    Newbie GT65coupe's Avatar
    Oct 2004
    London
    Dual GPS receiver ?
    Hi guys,
    Is it possible to use 2 GPS receivers at the same time?
    for more accuracy?
    Stephane
    1965 Ford Mustang coupe
    Ford Muscle & My 1965 Coupe
    V8 Powered
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I haven't seen it done before. But I can't see it making a difference. Wouldn't both the receivers be locked to the same sats? So what would be the point of haveing two.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Oct 2004
    London
    Quote Originally Posted by Quattro-A4
    well i don't know, that's why i am asking
    maybe to boost reception? I don't know
    V8 Powered
    Variable Bitrate HybridFox's Avatar
    Oct 2004
    Peterborough/Ontario/Canada
    basicaly from what i here the triangulate your position to within about 5 meters of acuracy.
    so it would be my guess that even if you did get it to work the best it would do is give you two positions 1-5 meters apart from each other so you could jus imagine yourself inbetween them
    best i can do
    Aug 2003
    Michigan
    that seems unlikely to help too much.. maybe if you wrote a program to average the position of the two, you'd get a slightly more accurate reading on where you are.. but i've found it to be fairly accurate for the most part.
    for boosted reception, theres a thread floating around somewhere about putting a refridgerator magnet under the receiver for increased reception (aka faster locking)
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
    Constant Bitrate blackpacu's Avatar
    Jul 2004
    Setauket
    I dont think it would make a difference if you had 2 or not
    I think quattro is right, they would just look on to the same sats
    I also havent seen any gps software that would be able to utilize 2 gps recievers either
    If you want to get better reception, i think getting a good reciever would be a better solution
    amd 1700, biostar m7ncg 400, hitachi deskstar 120 8mb , 512 pc2700, liliput 7"
    now to put it all together
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Actually more receivers will give you a more acurate position, but you would have to have software the takes into account the location of each receiver. There are multi-receivers systems that can give position within an inch or so.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
    Constant Bitrate Big Zack's Avatar
    Oct 2003
    I have two GPS receivers; one built into my laptop and the other is a USB puck.
    I have compared reading from two in two different applications, but I am not aware of any standard software (iGuidance, Copilot, SAT, Street Atlas) that will let you use more than one GPS receiver at a time.
    -Z
    Jun 2004
    Sydney, Australia
    D3 SDK lets you take data from a Buffer which you could fill by reading the GPS data stream yourself. It wouldnt be too hard to read the COM port data from each of the GPS and do some calculations before pushing it into the buffer.
    The thing i thought of was to have the GPS doing the readings half a second off synch. thatway you would get GPS signals every 0.5seconds instead of once per second...
    Oct 2004
    London
    Quote Originally Posted by Dominik
    interesting, can you code that?
    V8 Powered
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  2. what to look for in a GPS receiver?
    By doublestack in forum GPS
    Last Post: 10-01-2004, 04:05 PM
  3. Dual GPS Rcvr's. Unusual thought...
    By d_sellers1 in forum GPS
    Last Post: 06-21-2004, 08:26 PM
  4. CoPilot Software or USB GPS Receiver package
    By Zip-Lock in forum Classified Archive
    Last Post: 05-13-2004, 08:30 AM
  5. $69 12 channel GPS receiver - anyone tried this one?
    By LCDcrazy in forum General Hardware Discussion
    Last Post: 09-05-2001, 01:50 PM
