Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: loosing lock on.
    Oct 2002
    UK
    loosing lock on.
    I have the nice and cheap usb gps receiver from ebay and its starting to do my head in.
    I've moved it around all over my car.. worked for a while on my dashboard the my lilliput started to prevent it from locking on to anything. Now its in the boot on my parcel shelf and its nearly working.
    It locks on to 4-5 sats on average within several seconds but then again on averge looses its lock every now and then. Even when it has a clear view of the sky. Not brilliant when your trying to follow the route its giving to a destination.
    How does every find there lock on situation in built up cities? Mines pretty hopeless, looses lock on every few seconds when i'm in Manchester city centre.
    So solved the first problem of it getting a lock on, on start up.. but it just looses lock on quite frequently while driving.
    Volvo C70 - Installation in progress *gulp*
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    I'm having the same problem on my production machine. I know its not the GPS unit because I can get (and keep) a lock with my laptop without any problems.
    I have to say that its a software problem, most likely a driver issue because I have 3 navigation programs on the production machine. I have been trying to sort it out for the better part of 4 months now. I personally have a Deluo USB GPS.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Oct 2002
    UK
    I would say its the opposite for me. Theres a small red led which flashes on my GPS receiver when it has a lock on and this stops flashing every time it looses lock on. So even with no software running it still stops flashing and looses lock when it has a clear view of the sky.
    Anyone else got the cheap and cheerful (£35 - £45) gps receivers from ebay? Does anyone elses keep loosing lock on?
    Oct 2004
    Melbourne, Australia
    yep check the sticker on the bottom, its prolly a 'BU-303'.
    I just got one from Ebay the other day. Not the best reception, none at home even when im standing outside with the GPS connected to my laptop. Using Destinator driving home the other day it kept dropping out ('signal too low, check antenna' voice prompt) and would occasionally drop out completely ('GPS not found' voice prompt) meaning Destinator had lost seeing it and had to reconnect to it even tho windows still saw it.
    HP 9110nx P4 2.8ghz Laptop
    BU-303 USB GPS Receiver
    Oct 2002
    UK
    Quote Originally Posted by julz
    Just drove about 15miles from my gfs house on the motorway (full view of the sky) and it just lost lock after about 5mins. As I as going about 70mph it took another 5-10mins to get lock back on.
    Doesn't make sense though as I have heard several people who have this usb gps from ebay and it works perfectly. I'm thinking may be there isn't enough power going to it so i'm going to give some external power to the usb 2.0 pcmcia card its running from. If that fails going to try yet another place to put the receiver, why can't it just work first time eh!!
    I think the roof is the best place for it, the receiver seems to be waterproof, but just dont know how I will get the usb cable to it without drilling through my roof.
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    Have you placed it on something metal?? I'm noticing that with my BU-303, it REALLY likes having some sort of metal to sit on. Like the trunk lid, roof, even my door. Also, I've heard of 'problems' with the BU-303 and Destinator, but I woulnd't know first hand.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    Newbie Skorpion's Avatar
    Jun 2004
    i have the bu-303, and i couldn't get any lock on any sats inside my car.
    so i had to mount it on the roof, next to where the radio antenna comes out (which is where i fed the usb cable through too). and i get lock straight after returning from hibernation, and keep lock always. not sure how many sats i get though.
    i use destinator3, and i drive a 1991 toyota corolla seca.
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Are you using sirfr or nmea. I almost get rid of the problem by switching to sirf.
    http://www.mp3car.com/vbulletin/show...&postcount=684
    I also find that the actual orientation of the receiver helps. I couldnt find any logic on this, but,
    When i rotate it to make the red led face foward it improved signel by one third.
    My receiver ( BU-313 ) has a built in magnet in the bottom, I will try to put some metal base under it to check if the quality can be improved evem more.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Newbie iamag35man's Avatar
    Jul 2004
    Tampa, Fl
    The same thing is happening to me. I'm using the Earthmate USB Receiver. When I first put it in my car I put it in the front where the factory GPS antenna would have gone. It wouldn't lock on to anything. I guessed that it was getting interference from somewhere either from the Xenarc or the digital florescent display for the air conditioner. So I moved it to the rear deck. From there it works as you guys described. It will lock on for a while, then loose signal. It's random. I decided to put it on hold until after I installed my WiFi card. I put the WiFi antenna on the same rear deck and now the GPS receiver won't lock on to anything at all. I pulled the WiFi card out and then it works. My only other option for inside the car is to put the GPS receiver in the inside of the sunroof shade so it can see out the sunroof. Now I just have to pull the headliner out and run the cable. If that doesn't work. I might go down to the Honda or Mercedes dealer parts department and pick up one of their external roof GPS antenna covers and mount my Earthmate inside that either on the roof or the trunk lid.
    Xenarc 700TSV ■ Holux USB GPS ■ Creative USB Sound Card
    MB: Asus MATX ■ CPU: P3 1Ghz ■ 512MB PC133 ■ 80Gig HD ■ Griffin PowerMate
    PCI Wireless G & external antenna ■ ITPS + PS-200 PS
    Oct 2002
    UK
    Just had it on my roof and I almost keep the lock on through out my jouney, however going anywhere near a built up area with tall buildings it looses lock frequently which is a bit crap.
  1. Receiver won't lock!!
    By Bobby Digital in forum GPS
    Last Post: 05-09-2004, 08:59 PM
  2. gps takes forever to lock!
    By aznblueeboi in forum GPS
    Last Post: 04-23-2004, 12:52 AM
  3. Replies: 11
    Last Post: 01-31-2004, 08:57 PM
  4. earthmate wont lock onto satellite
    By aoLhaTer in forum GPS
    Last Post: 06-12-2003, 11:58 AM
  5. Replies: 4
    Last Post: 05-26-2003, 02:19 PM
