Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: BU-303 and SIrf
    Aug 2004
    BU-303 and SIrf
    Hi I have searched, but to no avail, this may sound ultra stupid as I don't yet fully understand the GPS thing, but.......
    How do I get Destinator to use my BU-303 in Sirf mode as I have heard it will update my position quicker etc....
    Do I need to switch its mode or anything?
    Many Thanks for putting up with what may be a stupid question
    Matt
    Aug 2004
    Sorry just found it!!!!
    Yes it's quite simple.Download sirfdemo.exe (from places like www.holux.co.uk) and connect to you gps device using the normal NMEA settings, then once connected select from one of the menus 'Switch to SIRF mode' and close sirfdemo. Now reconnect using SIRF/38400 in d3 and it should work
    Destinator 3.1 for PC - Right here!
    My bad!!!
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    Good work.. great find..
    •Micke
    Maximum Bitrate knubile's Avatar
    Do you have to do that every time you want to use it, or is it just a one time thing for the mouse itself?
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I havent had success with this....
    I connect to COM8 (the Prolific crap port - same as in destinator), then I put the baud at 4800 (same as d3 frontend), i go to "open source" thingy in the actions menu, (Otherwise the sirf mode option is greyed) then I get a bunch of data in the debug window, but nothing somes up in the other sirfdemo windows, then I select the "go to sirf mode" or whatever it is (it is no longer greyed), then I close go to d3, but it still only connect as NMEA/4800....
    I'm gonna try it again, but am I doing something wrong?\
    thnks!
    Oct 2002
    UK
    I managed to set it sirf mode using that program... just clicked on that 'change to sirf' option. Loaded Destinator 3 up and set the mode to sirf in the GPS settings and it found it ok.
    However the update rate didn't improve at all.. actually seemed to make it slower
    Is there any other way to make the Destinator 3 front end update faster as at the moment its about 30 ft behind my actual location when travelling above 30mph... gets a bit annoying when theres loads of streets and you have to work out which one you need.
    Volvo C70 - Installation in progress *gulp*
    Aug 2004
    Are you sure something else isn't wrong? I.E. not a good satilite lock as mine is now massivley better with sirf
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Quote Originally Posted by knubile
    CarPC install is starting to come along again...
    Aug 2004
    I can't tell you the offical answer, but I only did it once and its stayed in Sirf mode!!
    Oct 2002
    UK
    Quote Originally Posted by matty_g
    really? how many sats have you got a lock on to on average? I have about 4-5 on average and my gps receiver is on the roof so can't get a better location than that. Also its always loosing lock especially near built up areas which I was expecting but not as much as it is doing.
    Is Destinator much more accurate with sirf mode then?
