Results 1 to 7 of 7
Thread: Loading Destinator Client..
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Hey guys!
    Great work on the Destinator 3 SDK!
    However I have a problem, I did a clean install of Win98SE and loaded the Destinator 3 SDK with modified DLL and registered the DLL and OCX file myself as the register.bat file didn't work (kept saying C:\WINDOWS\REGSVR32 bad command or filename, however when I typed into the run dialog "REGSVR32 C:\DestinatorApps\Frontend\Mswinsck.ocx" it worked ) anyways the destinator client hangs at "Loading Destinator Client".
    It doesn't do the "Trying 1, 2, 3" thingy it just hangs and I need to do a Ctrl + Alt + Del to get rid of it. I tried running DestClient.exe on it's own and it started some hdd activity however then I got the dreaded illegal operation error! I have searched (especially in that monster thread over 40 pages long!) but i have found no real solution to this!
    Please Help!
    Btw: No firewall installed, and the destinator 3 SDK works fine on my WinME machine.
    Fox Mulder
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Xenarc 700TSV TS BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Try using regsvr rather than regsvr32
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Still Bad Command or file name, and the destinator client hangs at the loading screen. I will download the new 1.1 and try that tomorrow!
    Fox Mulder
    2004 Toyota MR2
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Has anyone with win98 got D3 working?
    Constant Bitrate ŠuTcH's Avatar
    Jan 2004
    Melb, Australia
    just tried it on my win98se machine, no go..
    can register the 3 files, and select the options for skin, 2d/3d, etc, then it hangs on loading destinator client, as what Fox_Mulder is geting
    Aug 2003
    Warrington, UK
    Confirmed. It's the D3 SDK, nothing I can do
    Looks like I will have to install WinME now as I confirmed it works on this OS...
    Fox Mulder
    2004 Toyota MR2
  1. CD/DVD drive - slot loading *and* USB?
    By SamDude in forum General Hardware Discussion
    Last Post: 11-08-2004, 02:41 PM
  2. cover for a slim slot loading dvd drive?
    By fasternfaster in forum Fabrication
    Last Post: 10-08-2004, 05:51 PM
  3. Replies: 0
    Last Post: 06-11-2004, 09:56 AM
  4. SR-8185 Not Loading!!!
    By sq_geek in forum General Hardware Discussion
    Last Post: 05-03-2004, 10:33 PM
  5. Smooth slot loading slimline drive-know of any?
    By psyclobe in forum General Hardware Discussion
    Last Post: 02-09-2004, 12:12 PM
