Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Adding POI's on the fly (speedcams)?
    The land of polar bears and nekkid blonds
    Is there a small utility out there that can store the current position and speed into a textfile (or something) for later use ?
    Over here the speedcam databases are few and old and since I travel a lot
    by car it would be nice to be able to add/refresh the info.
    /M
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    That's a great idea. Ninja monkey might be the best for doing this.
    Variable Bitrate aguila's Avatar
    Jun 2004
    the Netherlands
    yes nice idea
    MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
    http://www.mp3car.com/vbulletin/show-off-your-project/31991-audi-tt.html
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    D3, you just click the map and favourites!
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Quote Originally Posted by Laidback
    If only that menu could be a little larger!!
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Interesting...
    So just a button on the menu that when pressed will import your current Lat and Long into a CSV?
    Oct 2003
    Madrid
    Quote Originally Posted by Bravellir
    True, maybe in an ini file?
    Oct 2003
    Madrid
    Quote Originally Posted by Ninja Monkey
    Interesting...
    Edit: Not a CSV but a DAT file! Or of course you could open a text file and write any format you want.
    You could easily add a button to yours...
    Code:
                    Dim dis As DESTDLLLib.DestPoint
                    Set dis = New DESTDLLLib.DestPoint
                    Set dis = d.GetCurrentCarPosition
                    dis.Description = "Whatever"
                    Dim fName As String
                    fName = "Auto Alert 1"
                    d.AddPointToFavoritFolder fName, dis
    Aug 2004
    Netstumber and destinator
    Is there anyway of dynamically adding POI to destinator from an external script. Netstumbler now supports scripting, I wonder if it would be possible to add wifi hotspots to destinator as POI dynamically - cool.
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    i like where this is going...
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
  1. Texas Adding Wi-Fi To Highways
    By Confused in forum General MP3Car Discussion
    Last Post: 06-11-2004, 03:57 AM
