Results 1 to 10 of 10
Thread: GPS reciever reception indoors?
    Mar 2004
    Question GPS reciever reception indoors?
    Just wondering how everyone's reception works indoors... And what kind of indoor environment was this in?
    Also, does Bluetooth or WiFi interfere with the GPS signals?
    Newbie peegee's Avatar
    Oct 2004
    Massachusetts
    mine wont even find a sat if i am fully indoors, if i sit it near the window it will find sats and ill get 3d Fix.
    I dont think any would be able to find sats if fully indoors, but i could be wrong.
    Mine is a Rikaline 6010 (i beleive the same one CoPilot rebadges for sale with their GPS receiver/ Software pack.
    2002 Subaru Impreza WRX hatchback - Silver.
    IBM Thinkpad T21 800MHz 256Mb RAM 20Gb HD
    Lilliput 7", CoPilot, MediaCar
    Pyramid Super Blue PB442X 300w 4ch Amp
    Creative SB MP3+ USB
    Mar 2004
    But it should be fine going through a few layers of plastic, right? How under a metal sheet?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I have a Royaltek Sapphire and installed it underneath a plastic cover on my dash. It works...sort of. It takes a lot longer to acquire satellites and is more prone to dropping into 2d or losing lock completely. When I placed it on top of the cover in the identical position, it worked flawlessly.
    I'm almost certain metal will kill your sat reception. An easy experiment is to wrap it in one layer of Aluminum foil and try it.
    Want to:
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    GPS is a line of sight any signal that has to go around walls ( not a straght line ) will compermise the accuracy of the unit. GPS signal is RF and there for can not pass throuh metal or dense objucts.a ground plain will help recption as it will with most omnidirect antennae. with that said the best place to mount a GPS antenna is on your roof, as close to centered as posable.
    Mar 2004
    If it's RF, will a Bluetooth or 802.11g device in close proximity mess it up? Or no?
    Oct 2003
    never had a problrm with mine ,diferent freq ranges. cant say for all though denpends on your hardware
    Constant Bitrate ŠuTcH's Avatar
    Jan 2004
    Melb, Australia
    i have a bu-303 usb gps receiver, works indoors, picks up around 4 satellites, not a great signal strength though, and lock takes a fair while. i've also a belkin bluetooth usb dongle & rf mouse/mediaremote working in the car and home, doesn't make any difference, i think they work on different frequencies though.
    Low Bitrate l0gic's Avatar
    Essex - UK
    Quote Originally Posted by ŠuTcH
    This is my experience with the BU-303 as well.
    Running USB wireless LAN and USB Bluetooth as well does not seem to have any inpact on it.
    Kevin
    Build status {..........|} 99%
    All installed - now into the fiddling about stage
    Car:MR2
    MB: EPIA C800
    Display:Xenarc 700TS
    Power:PW-70A & ITPS
    Mem:384MB
    HDD:40Gb Maxtor Diamond max
    Radio:Dlink DRU-100
    GPS:BU-303
    OS:XP SP2
    Oct 2004
    On a sidenote, I emailed Garmin technical support about painting a GPS...
    Paint is generally not a problem for the GPS 35 unless the paint is reflective or absorptive at 1.5 GHz. Most paints are neither reflective nor absorptive near 1.5 GHz, so they have little effect on the performance of the GPS 35. About the only paints I've ever seen that cause problems are ones that are intended for use as a conformal shield or paints that are loaded with carbon or carbon fiber.
  1. CoPilot GPS reciever?
    By saintx in forum GPS
    Last Post: 10-18-2004, 11:38 AM
  2. Using Jap Pioneer GPS reciever in UK?
    By MegatronUK in forum GPS
    Last Post: 09-13-2004, 06:14 AM
  3. Whats a good GPS reciever?
    By SilverGT in forum GPS
    Last Post: 07-08-2004, 11:28 AM
  4. Holux GPS NMEA reciever Group-buy?
    By vickumar in forum General Hardware Discussion
    Last Post: 04-24-2002, 06:09 AM
  5. How about THIS GPS Reciever??
    By ppgt94 in forum GPS
    Last Post: 04-15-2002, 07:26 PM
