yes. Delorme has an USB to Srial driver for the earthmate. I have the same thing, and got it to work. I'll search up the link for you. ok? hold on...![]()
I searched, didn't find anything.
I've got the DeLorme SA (usb) receiver, works fine with DeLorme software.
I installed iGuidance 2.0 and can't get it to work. Can't get it to see my GPS receiver.
I uninstalled the Delorme crap and rebooted. I installed driver files from the Deluo website (Routis): http://www.deluo.com/support/faq/ind...&id=17&lang=en
Should they work? Routis is the same right?
Should I also install the USB to Serial adapter driver? If so, in what order do I do all this?
Has anyone done this? Could you tell how you got this to work?![]()
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
Yes you need the usb to serial adapter. Follow the instructions on the delorme page.
[COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
http://delorme.com/support/gps/uemat...=&P=17111&C=19
and
http://www.delorme.com/support/earth...rdpartytrb.asp
To Verify the Correct Installation
From the Start menu, point to Settings and then click Control Panel.
Double click the System option.
Click the Device Manager tab.
Click the plus sign next to Ports (COM & LPT).
Verify that the DeLorme Earthmate GPS COM device is listed
If the Device is not listed then click the plus sign next to Human Interface Devices.
If the device is listed as a USB Human Interface device, update the driver.
Make sure you do that. It is from the second link!
darn you beat me to it. good job. I had it too though.,![]()
you learn as you go here... didn't even know of the solution until i read it somwhere over here...![]()
Oops, deleted my thanks post, Man I must be tired or something.
Anywho: Thanks! I searched everywhere BUT Delorme, duh...
EDIT: Got the file. Thanks
Should I uninstall iQuidance first? Delorme is already uninstalled (guess I didn't need to do that) Load the "GPS Update and COM Port Emulation Drivers" and then reinstall iGuidance?
you dont need to reinstall. just nstall the drivers, and in iguidance go to tools>gps>detect
easy as that. It'll recognise in no time.
OK, thanks again.
