Results 1 to 10 of 18
Thread: earthmate usb gps with MS Streets&Trips?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Ok, i jumped on the gps boat about 2 weeks ago. I picked up the Delorme Earthmate USB GPS reciever that came with Street Atlas 2005. Since this is the first gps software ive ever used i guess its good but still left me wanting more. So today i picked up MS Streets&Trips 2005 (only30bucks so i said what the hell).
    PROBLEM:
    I cant seem to get my earthmate USB GPS to work with MS S&T
    Ive installed the usb to serial emulation drivers from the CD, even downloaded them from the site just to make sure i had the latest version of the drivers.
    MS keeps saying that it sees my gps device but the data coming from it is not NMEA compliant.
    This is the receiver I have http://www.delorme.com/earthmate/specifications.asp
    and right on the site it says the device IS NMEA complient
    How do i get these two to work together?
    Or did i just buy a 30 coaster
    I also search but still cant get it to work.
    Aug 2003
    Chicago
    still doing some searching everywhere, it seems that there are multiple versions of the usb driver, not sure which one is the one that will work. THe latest version on the delorme site is usbmate2.exe (something like that). Is this the version i should be using?
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Get the driver with the latest date. That usbmate2 might be the one. After install, look in your Device Manager to see if the Earthmate appears on a comm port.
    The Earthmate is definitely NMEA compliant - mine works with SA, iGuidance, Routis, Mappoint, etc. and I can read the data stream with Hyperterminal.
    Aug 2003
    Chicago
    the driver is installed correctly, that was my first place to look to make sure it was in right. Ive had similar problems with bluetooth devices not being installed correctly because of windows forceing its own drivers. I wish i had something else to test this with, all i have is SA and S&T and the test utillity that comes with the earthmate, none of which will work except the SA. Ill keep trying though. Im glad that others have gotten it to work, so ill just keep hacking at it.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    This you look into this thread yet?
    Possible help for USB Earthmate and Routis/IGuidance
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Aug 2003
    Chicago
    yup
    Aug 2003
    Chicago
    OK, I seem to have it working now.
    Not sure what the hell the problem was, i didnt do anything different than what i was already doing before i even posted. I just kept installing and uninstalling the driver, connecting hyperterminal, and trying to get MS S&T to work. Then BOOM it started working.
    Anyway, does anyone know of a way to make it auto track my position, it sucks that you have to tell it to do it everytime you start the program. Also, is there anyway to add more map views (different colors). Ive gotten really fond of the high contrast view in Street Atlas, its easy to see everything in the day and night. The MS maps dont have enough contrast and look washed out. They are more accurate though than the Street Atlat maps (it seems) and dont have that damn bread crumb thing and just use a line. Damn car icon is way too small.
    One of the things i notice between these PC gps applications and OEM nav software, is that the OEM nav stuff has way better maps and way easier to see and understand where you are. Are there any PC apps that come close to this. I dont think im close to being happy with either Delorme or MS products.
    Although, delorme did save me a boat load of time the other day. There was major traffic on 290 in chicago and i wanted to bypass all this and take local roads. Local roads which i dont know from a hole in the ground, and it helped me avoid the traffic and even put me back on track when i made several wrong turns. Turned a 45min stop and go trip to 15min.
    Aug 2003
    Chicago
    Well it seems that it dosent work 100% all the time. Im not quite sure why but MS Streets will still say the data coming from the GPS is not NMEA. Is it possible that Street Atlas is changing the data output of the GPS device when it loads. When MS says its not NMEA data, i connect the hyperterminal and the data is a bunch of non recognizeable characters. If i reboot, and dont connect anything to the gps com port and load hyperterminal the data looks fine.
    I also cant seem to get the XPORT app to work either, it keeps crashing and hanging or giving errors that the imput com port is wrong or something. Or it dosent even show the com port that my gps is on as available (missing from list of ports).
    any ideas?
    Hopefully i can get some better GPS software that works better and more supported in the frontends like destinator or routis or whatever.
    New York
    Well, with the Earthmate driver installed for 3rd Party usage, there are quirks. One being that which you described. First, you must make sure the 3rd Party Driver is Installed via the Device Manager, and not the installed software Delorme provided which is buggy.
    Beyond that... if you start by using a NMEA Navigation software such as Ms S&T, the Earthmate will send NMEA signals. The moment you start up any DeLorme Software, it will trigger the Earthmate into the binary Rockwell Signal and will no longer send any NMEA signal. From this point on, the only way (that I know of) to get it to send NMEA signal again, is to restart the computer or to unplug and replug the Earthmate to get it to reset itself.
    Jul 2004
    Rancho Cucamonga, CA
    MS streets and trips is not meant to be a navigation program and it doesnt do a very good job for this. I am very happy with iguidiance, it works great and fucntions very close to my friends navagation system ( i think he has a pioneer or kenwood system).
    EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
    My Truckputer
  1. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 03:24 PM
  2. Replies: 21
    Last Post: 06-30-2004, 02:17 AM
  3. Help with drivers for USB Earthmate?
    By kandyman676 in forum GPS
    Last Post: 06-04-2004, 08:44 PM
  4. FS: Group Buy USB GPS Receiver (BU-303)
    By Toups in forum Classified Archive
    Last Post: 03-15-2004, 07:32 PM
  5. Replies: 5
    Last Post: 01-04-2004, 10:43 PM
