on page 7 there is a resource hack, im pretty illiterate with computers and was able to figure out how to replace the bitmaps with these, its pretty simple, jsut takes a bit of time.
may be dumb..nut ok ihave both files(.exe) now what the heck do i do with them? cant put them in same directory.can someone shed some light on this please.
..and dont back out just because u think its too crazi , i hate pussies
-outdidya
epia m1000,256mb ddr,7"lilli,120gb hdd, Ati remote wonder,400watt inverter,350psu all under xp pro-installed
ok i was just playing abit more with the "iguidance.exe" in resource hacker ,I was looking in the "dialog" section in resourcehacker and decided to JUST change the font for each dialog
this is dialog # 1026 - went from 10 font to 14 - it changed the whole dialog made it bigger and all working
[EDIT] It seems that only a couple of dialogs wont be affected by just making the font size bigger, some have problems with the bitmaps not be big enough when just adding a bigger font
Here is a PIC
you are a dang genious. isnt universal, but works for the most part extreemely well!
any luck with that speed readout at the lower right of your pictures there?
na no luck with the speed readout, i checked the exe and I cant find any info on it,Originally Posted by WhiteRabbit
maybe frodo or Veetid can have a look at it - it might be hardcoded just like the keyboard layouts
if its hardcoded, does that mean ultimately we are SOL?
i got all that down pretty easy i was referring to the exe files, how do i merge them together or do i?
-outdidya
Its a spanned archive, just unzip the first one and it will automaticly unzip the second file and join them together.Originally Posted by fallnangel
cool thanx alot for the info.
-outdidya
How do I impliment those? The tiny pointer thing has been my biggest problem with iGuidance.Originally Posted by WhiteRabbit
