okay, grab my zip file there, its 20 pictures, 18 of them are various pointers, two are the zoom buttons. they are all labeled by a three digit number.
now go back to page 6 or 7, I think it was 7, there is a link for a resource hack program. grab that, then open up
iguidance.exe.
youll see a folder called bitmap with a zillion bitmaps inside for all the different icons you can change. they are all labeled using three digit numbers. I run routis, so mine correspond to the icons in routis.exe, number by number, so its completely brainless.
you may have to confirm the icons are the same, itll display the icon in the resource hack.
one of the menus has an "exchange bitmap" or some command like that, you can use that to change the bitmaps, simply point to where you extracted the bitmaps to, then save out the .exe, and its now written in!
makes it much much easier to see. its just a teeny touch too big in 800 mode for streets that are extreemely close together, but I find it much much much nicer than the original bitmap size.
good luck!
