Originally Posted by fantomas
My legal name is David... changed it from Dmitry.
have it say "Welcome Scott" ...and if scott's not your name, then legally change it.Originally Posted by 0l33l
rebuilding carpc... kinda..
Good callOriginally Posted by 0l33l
CarPC install is starting to come along again...
I have used Resource Hacker on AIM 5.1, to make it so much better. I'm not a big fan of the way AIM has gone, so I either use my Resource Hacked AIM 5.1 which went with my old desktop theme or I use MirandaIM. Anways, I am pretty good with it and have experience with it from over the years. When I get done re-fabricating my dash and console pieces, and have time, I will give it a try![]()
Sounds good..
Giddyup!
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
Allright I'm going goofy trying to change the color of the guidance line. The actual planned out route...the bright yellow line you follow in guidance mode.
Anyway, I can change teh colors of everything else. I can change the width of that line. But I can't seem to change the color of that line for anything.
I'm modifying the THEME.INI file on this line
; day guidance road color
DGRDC=24,163,62 24,163,62 24,163,62 24,163,62 24,163,62
But it doesn't change anything.
What am I doing wrong?
Allright I figured something new out that many of you probably already know.
The icons of things like the interstate symbols and ATMs and stuff are all double layered. Each file contains two images, a large one and a small one. The program decides which to display.
How do you edit both and store them back in the same file?
i remember reading somewhere that not all setting are working yet in the theme.ini file!Originally Posted by Skipjacks
Check out this pic, I like the colors and look
this is not iguidance, i beleive its for a PDA, dont now the name though
I like Dmitry better.Originally Posted by 0l33l
[H]4 Life
I'm a lesbian too.
I am for hire!
Its weird. My real name was Dmitriy, but it was always spelled something different, like forgetting the I, or foregoing the Y, etc... Now David is so easy to spell, and its very commonOriginally Posted by frodobaggins
At home I'm called Dima.
