Page 26 of 45 FirstFirst ... 161718192021222324252627282930313233343536 ... LastLast
Results 251 to 260 of 449
Thread: Iguidance 2.0 font size is killing me
  1. #251
    Newbie schillrw's Avatar
    Feb 2005
    Baltimore, MD
    I have done this and seen no changes. I have the newest version of iGuidance, is that why?
    2004 F150 Lariat SuperCrew 4X4
    Lilliput 7" Mounted In Dash
    Via M10000
    256MB PC3200 DDR
    60gb Maxtor 7200RPM
    Sony 16X DVD Drive
  2. #252
    Constant Bitrate takissd's Avatar
    May 2004
    San Diego, CA
    Quote Originally Posted by schillrw
    i have done it too on the new iguidance and at the beggining i saw nothing. then i restarted the pc and it all worked out. make sure the file is theme.ini cause sometimes when you edit it it is called and seen as theme.ini but is actually theme.ini.txt
    remember to restart and it has to work..
    -VIA EPIA M10000/512MB/40GB HD
    -DWW motorized 7'
    -BU 303 GPS w/iGuidance/ CF
    -Opus90w
    -Belkin Bluetooth
    -Pioneer HU
    [||||||||||] 95% done
  3. #253
    Newbie ysutarko's Avatar
    Mar 2005
    Artesia, CA
    this is what i got so far
    just need to figure out how to change the background to White(Day) and Black(night)
  4. #254
    Feb 2005
    Baltimore, MD
    I restarted once I know but I will try that again. I am very aware that it has to be theme.ini and not theme.ini.txt
    Via M10000
    256MB PC3200 DDR
    60gb Maxtor 7200RPM
    Sony 16X DVD Drive
  5. #255
    May 2004
    San Diego, CA
    sometimes windows hides the extension and it still looks as a .ini file..
    but if you are sure about it i guess there is something else wrong. I did the same thing to both mine and my friend's carpc and it worked.
    try making a new file and add only
    ; street name font size in points @ zoom level
    STS=20 20 20 20 20 20 20 20 20 20 20
    save it as theme.ini and try again... this only makes street font size a lil bigger change the 20 to a bigger number for larger font..
    Else i guess i would install Igudance again copy file and try it..
    -DWW motorized 7'
    -Opus90w
    -Belkin Bluetooth
    -Pioneer HU
  6. #256
    can someone pm me the theme2.ini file? come one guys... I know some of you have it. Please share the wealth.
  7. #257
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Quote Originally Posted by badandy
    Your specific answer is right here.... this is on a silver platter... I tried it myself.
    http://www.mp3car.com/vbulletin/show...50&postcount=9
    Okay guys... it's time to try a bit harder. I am not normally one to wave the flag, but in this case... everthing you need is in this thread. I had not done the update myself yet as I had not had a chance and I am here to tell you that it worked for me first attempt. I simply did a cut/paste/save as theme.ini with notepad in the same directory as iguidance.exe and it worked first time. You will just have to try a bit harder, it's no more complicated than that. If it still does not work, your will have to call INav for tech support or try a re-install as there must be something wrong with your installation. This thread is already big enough without more begging.
    Sorry... I feel for you guys, but this does work and it is not rocket science...
    I suggest using this thread to get your troubles sorted out. Shrillw started it...
    iGuidance theme.ini
    Good Luck campers
  8. #258
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    ok, so what about theme2.ini???
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
  9. #259
    Mar 2005
    NYC
    where exactly do i go to edit the theme.ini to increase the fonts that were posted?
  10. #260
    Feb 2005
    New Orleans, LA
    just open it with notepad and get to the part at the bottom of the file that says
    the 20's are the font sizes. Just so you know this line is all that is in my theme ini file cuz I just wanted the fontsize changed and nothing else.
    1997 VW Jetta GLX VR6
    old HP MP
    PIII 600 or so 256 MB
    7" Xenarc
    and some plywood holding it all together
    My Project
  1. IGuidance 2.0... WOW
    By unsavory in forum GPS
    Last Post: 04-20-2005, 02:14 AM
  2. Replies: 1
    Last Post: 11-17-2004, 07:46 PM
  3. Embedded iGuidance Window Size?
    By All4Sky in forum MediaCar
    Last Post: 08-27-2004, 09:00 AM
  4. winamp and play list font size????????????
    By donalson in forum Software & Software Development
    Last Post: 02-28-2001, 08:40 PM
  5. changing font size of file names in Windows Explorer?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-11-2001, 05:49 PM
