Page 28 of 45 FirstFirst ... 181920212223242526272829303132333435363738 ... LastLast
Results 271 to 280 of 449
Thread: Iguidance 2.0 font size is killing me
  1. #271
    Raw Wave justintime's Avatar
    Apr 2005
    If you guys want to make all the windows look more authentic (more 'car pc navigator' like) you can use reshacker, and then do the following to remove the menu bars. (The window's menu bar used to drag windows... who needs that?)
    1) Select the dialog
    2) Right click dialog window, and select EDIT DIALOG from the contextual menu.
    3) On the bottom left, there is a list. Some items will be highlited in yellow. Find WS_DLGFRAME and hilite it.
    4) Save compile etc.
    You can do this for every dialog. They look much more authentic WITHOUT the windows menu bar!
    Screenshot:
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  2. #272
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Great idea, thanks for the info.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  3. #273
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You can even make all buttons bigger. Just resize them in res hack.
  4. #274
    Dec 2003
    New York
    but does the control area for the buttons increase as well??
    I think thats what been the problem.
    Installed
  5. #275
    Apr 2005
    YES, it does increase accordingly. For BUTTONS, it does.
    Quote Originally Posted by Quattro
    2002 Honda CR-V
  6. #276
    FLAC Marvin Hlavac's Avatar
    May 2005
    Hi guys,
    I like the modifications above. I never heard of ResHacker before. I think I should check it out. Is it possible to use ResHacker to enlarge the little rectangle which displays ETA, REM, DEST, and SPEED?
  7. #277
    Apr 2005
    I looked, and could not find it. I looked all over!
    Quote Originally Posted by Marvin Hlavac
    Hi guys,
    2002 Honda CR-V
  8. #278
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by justintime
    Screenshot:
    I followed the above steps to do this for routis, which has basically the same exe file as iguidance but did not work. What am I doing wrong?
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  9. #279
    Apr 2005
    When you hilite the option, it should be yellow. Also, the 'preview' of the window itself will suddenly show only one window bar (instead of two). Its confusing, I know.... there is one window bar for the 'ResHacker window', and another menu bar showing within, which is the 'Routis/iGuidance' window. All of this shows while working within the ResHacker interface...
    OK, so you hilite the option as per instructions, you compile, and save. The 'preview' should now show only one menu bar, and you know you've done it correctly.
    Quote Originally Posted by Zebelkhan
    2002 Honda CR-V
  10. #280
    Dec 2004
    Bay Area, CA
    I just tried it on all of the dialogs and it works on all of them exept the main one which shows the map. Just thought of something though. I am opening routis as an stand alone application. Maybe what I am seeing is the "windows" frame and I should be opening it within FP or RR? I don't have them on my desktop (that is where I am testing this) I will download FP and open routis from within to see if it works.
  1. IGuidance 2.0... WOW
    By unsavory in forum GPS
    Last Post: 04-20-2005, 02:14 AM
  2. Replies: 1
    Last Post: 11-17-2004, 07:46 PM
  3. Embedded iGuidance Window Size?
    By All4Sky in forum MediaCar
    Last Post: 08-27-2004, 09:00 AM
  4. winamp and play list font size????????????
    By donalson in forum Software & Software Development
    Last Post: 02-28-2001, 08:40 PM
  5. changing font size of file names in Windows Explorer?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-11-2001, 05:49 PM
