Page 29 of 45 FirstFirst ... 192021222324252627282930313233343536373839 ... LastLast
Results 281 to 290 of 449
Thread: Iguidance 2.0 font size is killing me
  1. #281
    Raw Wave tj!2k4's Avatar
    Oct 2004
    If you want to be rid of the iGuidance menu bars, I suggest you check out ol33l's iGLaunch app
    [Release] iGLaunch v3
  2. #282
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    It works! Thanks. Now if I could get rid of the file menue bar (the one that has the text menue) and even the one right below it that has the icons. Any ideas on those?
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  3. #283
    Raw Wave justintime's Avatar
    Apr 2005
    Yeah, iGlaunch does not get rid of those for me either
    It is SUPPOSED to though!
    Quote Originally Posted by Zebelkhan
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #284
    Oct 2004
    it does for me.
  5. #285
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by tj!2k4
    it does for me.
    I used the resource hacker on routis and it works except does not get rid of the text menue and icon bar below it. I then tried iglaunch (after changing the ini file for routis) but something is not right as the nag bar does not go away and when routis embeds into iglaunch it sits there and flickers for what it seems at least 100 times. But it looks like it does get rid of all the menue bars. Assuming I can get it to work, how do I launch iglaunch automatically when I launch routis?
  6. #286
    Oct 2004
    in whatever frontend you're using, specify the path to iGLaunch.exe, and also tell it that the windowname is iGLaunch. In the iGLaunch.ini file, you specify the path to the routis.exe.
    As far as the nag window, that is probably a timing issue, I am having problems with it on my desktop, but in the car it now works. Hopefully ol33l will look into it some more.
  7. #287
    Dec 2004
    Bay Area, CA
    Thanks!
  8. #288
    Apr 2005
    OMG! Thanks dude. That was my problem.
    I was using "iGuidance" as the window name, instead of "iGlaunch". Now that I use the correct settings in CF, it works like a dream.
    [Edited to correct window name]
    2002 Honda CR-V
  9. #289
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Thanks for the plug... I didn't feel like posting it in this thread
    Well, the timings are adjustable. I wonder why its not working on your home PC. Its not like you're using a 400mhz AMD processor at home
  10. #290
    Banned
    Dec 2004
    I couldn't get rid of the tool bar.
  1. IGuidance 2.0... WOW
    By unsavory in forum GPS
    Last Post: 04-20-2005, 02:14 AM
  2. Replies: 1
    Last Post: 11-17-2004, 07:46 PM
  3. Embedded iGuidance Window Size?
    By All4Sky in forum MediaCar
    Last Post: 08-27-2004, 09:00 AM
  4. winamp and play list font size????????????
    By donalson in forum Software & Software Development
    Last Post: 02-28-2001, 08:40 PM
  5. changing font size of file names in Windows Explorer?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-11-2001, 05:49 PM
