Page 34 of 45 FirstFirst ... 242526272829303132333435363738394041424344 ... LastLast
Results 331 to 340 of 449
Thread: Iguidance 2.0 font size is killing me
  1. #331
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Can anyone list the complete color codes, i.e.
    0,255,0 = yellow
    0,0,255 = blue
    etc.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  2. #332
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by RPM_VR4
    I just got a copy of 2.1 (I don't think it is 2.1.1 as the File|About just has V2.1NA) and I can't get it to work. My 2.0 theme.ini does nothing, and if I rename it to ctheme.ini, I get:
    "iGuidance has encountered a problem and needs to close. We are sorry for the inconvenience."
    As soon as I double click the exe.
    Can someone PM me the contents of a theme2.ini/ctheme.ini that works with 2.1?
    I believe your only choice for theme files is theme.ini and ctheme.ini. Does your software start normally if you remove the theme file. If I remember correctly, there might be other theme files in the directory WHICH YOU SHOULD NOT TOUCH. Only create either theme.ini or ctheme.ini, and add them to the directory.
    If the program won't launch after removing the theme or ctheme.ini, I would reinstall the software, adn try again.
    Michael
  3. #333
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Just so people are aware.
    The DVD version 2.1.1 of Iguidance uses "theme.ini" and not "ctheme.ini"
    Michael
  4. #334
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Quote Originally Posted by Zebelkhan
    0,255,0 = yellow
    0,0,255 = blue
    etc.
    You do realize there are 14 million of them right?
    It's R, G, B so 255,0,0 is 100% red with no green or blue. 255,255,255 is white, 0,0,0 is black, 255,0,255 is red+blue=purple.
    You should use some paint program or a web-page editor to choose the color you want and then read the code (you may have to convert from hex [#FFFFFF] to decimal [255,255,255] using calculator).
  5. #335
    FLAC Marvin Hlavac's Avatar
    May 2005
    There are several web sites that will provide at least the basic color palette. Here is one: Just click on the color of your choice inside the image on top left side of the page and you will be presented the RGB value.
    Many people have Microsoft Word on their computers. You can easily achieve the same, and have access to the whole spectrum of colors, just by starting your MS Word, and on the Formatting toolbar click the little arrow beside the Font Color button (The button with letter A icon). There click "More Colors", and then again click "Custom". Make sure RGB is selected as Color Model. When you click on any color of the spectrum you will see corresponding RGB value below.
  6. #336
    Dec 2004
    Bay Area, CA
    Thank you! I did not know what those codes meant. Thanks for the sugestions.
  7. #337
    Raw Wave lostreception's Avatar
    NY
    Someone had asked about enlarging the ETA /Dest/speed dialog i was wondering if the answer was the same for enlarging the distance to the next turn in the upper left hand corner
    has anyone been able to do this?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  8. #338
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by lostreception
    Not that I know off
    In future versions of iGSkinner, I'll try to magnify that area.
  9. #339
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    wow, this thread is out of control well not out of control but really long and over 17k views, holy crap.
    Anway, i think i get 2-3 PM's a week asking for the IG font fix, although all the info (including the file) is right here in this thread.
    So, to try to cut down or get rid of all the PM's ill post the info again.
    Maybe someone can make a new thread with all the usefull info and projects that spawned from this thread so people dont have to search through this thread to get all the info.
    Here it is, again.
    Quote Originally Posted by liquid_smoke
    Copy the text below into a new text file and name it "Theme.ini" and place this file in the same dir as iGuidance.exe is located. Edit the text size at teh bottom of the file, other options can also be changed in this file, take a look here on how to properly edit the file.
    Code:
    ; road pen width in pixels @ 100ft FC1-2-3-4-5
    RPW0=6 6 6 6 6
    ; road pen width in pixels @ 200ft FC1-2-3-4-5
    RPW1=6 6 6 4 4
    ; road pen width in pixels @ 500ft FC1-2-3-4-5
    RPW2=6 6 6 4 4
    ; road pen width in pixels @ 1000ft FC1-2-3-4-5
    RPW3=3 3 2 2 2
    ; road pen width in pixels @ 2500ft FC1-2-3-4-5
    RPW4=3 3 2 1 1
    ; road pen width in pixels @ 1mi FC1-2-3-4-5
    RPW5=3 3 2 2 1
    ; road pen width in pixels @ 2mi FC1-2-3-4-5
    RPW6=2 2 1 1 1
    ; road pen width in pixels @ 5mi FC1-2-3-4-5
    RPW7=2 2 1 1 1
    ; road pen width in pixels @ 10mi FC1-2-3-4-5
    RPW8=1 1 1 1 1
    ; road pen width in pixels @ 25mi FC1-2-3-4-5 (DISABLED)
    RPW9=1 1 1 1 1
    ; road pen width in pixels @ 50mi FC1-2-3-4-5 (DISABLED)
    RPW10=1 1 1 1 1
    ; day map road pen color FC1-2-3-4-5
    ; to use same colors for all zoom levels only specify DMRPC(max)
    DMRPC0=255,29,34 255,29,34 230,143,38 153,115,98 153,115,98
    DMRPC1=255,29,34 255,29,34 230,143,38 153,115,98 153,115,98
    DMRPC2=255,29,34 255,29,34 230,143,38 153,115,98 153,115,98
    DMRPC3=255,29,34 255,29,34 230,143,38 157,119,102 157,119,102
    DMRPC4=255,29,34 255,29,34 230,143,38 167,131,116 187,160,149
    DMRPC5=255,29,34 255,29,34 230,143,38 153,115,98 175,147,133
    DMRPC6=242,0,8 242,0,8 230,143,38 175,147,133 175,147,133
    DMRPC7=242,0,8 242,0,8 230,143,38 153,115,98 145,107,91
    DMRPC8=242,0,8 242,0,8 230,143,38 153,115,98 145,107,91
    DMRPC9=242,0,8 242,0,8 230,143,38 153,115,98 145,107,91
    DMRPC10=242,0,8 242,0,8 230,143,38 153,115,98 145,107,91
    ; nite map road pen color FC1-2-3-4-5
    ; to use same colors for all zoom levels only specify NMRPC(max)
    NMRPC0=255,0,0 255,0,0 255,133,136 255,255,255 140,140,140
    NMRPC1=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190
    NMRPC2=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190
    NMRPC3=255,0,0 255,0,0 255,133,136 255,255,255 150,150,150
    NMRPC4=255,0,0 255,0,0 255,133,136 255,255,255 120,120,120
    NMRPC5=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190
    NMRPC6=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190
    NMRPC7=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190
    NMRPC8=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190
    NMRPC9=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190
    NMRPC10=255,0,0 255,0,0 255,133,136 255,255,255 190,190,190
    ; route pen width @ zoom level
    RTPW=6 6 6 6 6 6 6 6 6 6 6
    ; guidance screen route pen width
    GRPW=6
    ; guidance road pen width
    GRDPW=6 6 6 6 6
    ; day guidance road color
    DGRDC=192,0,0 192,0,0 128,192,192 192,192,192 192,192,192
    ; night guidance road color
    NGRDC=192,0,0 192,0,0 32,96,96 96,96,96 96,96,96
    ; street name font size in points @ zoom level
    STS=10 20 20 20 20 20 20 20 20 20 20
    ; route colors
    RTC=0,0,255 0,0,255 0,255,0 0,255,0
    [/QUOTE]
  10. #340
    Raw Wave justintime's Avatar
    Apr 2005
    For everything related to iGuidance customization, bookmark this thread (http://www.gpspassion.com/forumsen/t...TOPIC_ID=28166)
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  1. IGuidance 2.0... WOW
    By unsavory in forum GPS
    Last Post: 04-20-2005, 02:14 AM
  2. Replies: 1
    Last Post: 11-17-2004, 07:46 PM
  3. Embedded iGuidance Window Size?
    By All4Sky in forum MediaCar
    Last Post: 08-27-2004, 09:00 AM
  4. winamp and play list font size????????????
    By donalson in forum Software & Software Development
    Last Post: 02-28-2001, 08:40 PM
  5. changing font size of file names in Windows Explorer?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-11-2001, 05:49 PM
