Page 36 of 45 FirstFirst ... 2627282930313233343536373839404142434445 LastLast
Results 351 to 360 of 449
Thread: Iguidance 2.0 font size is killing me
  1. #351
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by Marvin Hlavac
    Actually my solution is something which most people in this forum will likely not find interesting, because in my setup I use a small keyboard instead of a touch screen. And since I control everything iGuidance related with my keyboard I created a hotkey that will: 1.) Start iGuidance and Magnifier at the same time. 2.) When the hotkey is used when iGuidance already runs, it will minimize iGuidance and it will at the same time close Magnifier. 3.) When iGuidance is minimized, the hotkey will restore iGuidance and it will start Magnifier.
    Marvin, could you share how you created this hotkey?
  2. #352
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by tj!2k4
    Martin, could you share how you created this hotkey?
    Go to his website. He has a program called IGKey or something like that. It utilizes several hotkeys to accomplish functions in IG.
    Michael
    P.S. ETA appears when you are in guidance mode. That is after you have entered an address and have began your trip to the location, ETA appears. Marvin is using a magnifier program to enlarge and display the information.
  3. #353
    FLAC Marvin Hlavac's Avatar
    May 2005
    Thanks, but it is not my website, even though I do spend a lot of time there
    I just started to use The Magnifier recently, and even though I have been testing and improving the hotkey for the function for a while, I never took the time to integrate it to iGkeys. But I just needed this little kick this morning ;-)
    Here it is, new version of iGkeys, incorporating support for The Magnifier:
  4. #354
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Here it is, new version of iGkeys, incorporating support for The Magnifier: http://www.gpspassion.com/forumsen/t...TOPIC_ID=26018
    Who said nothing good comes out of Canada? Certainly not me.
    I thought it was "your" site Marvin. I apologize for the mis-information.
    Michael
  5. #355
    Oct 2004
    Thanks for sharing that..
  6. #356
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Marvin,
    I run my iGuidance from within a front end (frodo). Is it true that I should not be using the magnifier as it will magnify the front end when it is focused instead of GPS? Is there a way to get around that? Thanks
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  7. #357
    May 2005
    @ Wiredwrx: Gpspassion.com is owned by a person in France ;-)
    @ Zebelkhan: You'll never know unless you try ;-) Trying is free ;-)
  8. #358
    Apr 2005
    Queens, New York
    Hey Marvin, I just downloaded iGKeys. I am mainly just using it for CTRL + Q for the magnifier.
    I have iGuidance embeded into Centrafuse Front End. Ig i have the screen on GPS Magnifiers works great but if i switch to something else like Media or an other screen that it is not show iGuidance, the magnifier is still there but showing whatever spot i locked into on the screen. I was wondering if there is a way to have magnifier only show when i am at the GPS screen in Centrafuse.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  9. #359
    Apr 2005
    Queens, New York
    Kinda like have Centafuse Overlap THE MAGNIFIER when GPS not being viewd....
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  10. #360
    May 2005
    I will leave that one up to the front end gurus here at this forum. I have no experience in the area. I just run WinXP with no front end.
    (But if some idea comes up, I will share...)
    P.S. When iGuidance is not being used The Magnifier should be closed. When you re-open it, it will always be where you need it (the same place).
  1. IGuidance 2.0... WOW
    By unsavory in forum GPS
    Last Post: 04-20-2005, 01:14 AM
  2. Replies: 1
    Last Post: 11-17-2004, 06:46 PM
  3. Embedded iGuidance Window Size?
    By All4Sky in forum MediaCar
    Last Post: 08-27-2004, 08:00 AM
  4. winamp and play list font size????????????
    By donalson in forum Software & Software Development
    Last Post: 02-28-2001, 07:40 PM
  5. changing font size of file names in Windows Explorer?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-11-2001, 04:49 PM
