Originally Posted by muldrick
theme2.ini is an advanced settings file. As I understand you rename it theme.ini and use it instead of the other theme.ini. It changes other appearances on the map. Can anyone back me up with more info?
You have to make it and put the info in.Originally Posted by icet
[H]4 Life
I'm a lesbian too.
I am for hire!
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
yeah thats what I thought...Originally Posted by n8scstm
I just wish there was a way to change the size of the menu buttons... I have to use a stylus in my car because of how small the iguidance buttons and menus are... I saw someone who was able to make them any size he wanted at the last meet I went to. The just used a resource editor to open up the exe, extract the bitmaps from it... then chagned there size and put them back in... They had tripled the size of the zoom buttons and it looked awesome, but I haven't had time to try it yet...
EDIT: Just went and downloaded Resource Hacker from
http://www.users.on.net/johnson/resourcehacker/
Use that program to open up the iGuidance.exe and under Bitmap you will see all the buttons.. Now someone just needs to make a larger button, import them all into the iGuidance.exe, and re-save it out...
You can change just about everything through this program... Street and Highway icons, Whats displayed in the file menu, what the hotkeys are, all the icons, you name it... I haven't actually changed and saved anything back out yet, but I know it should work because I saw it running modified in someones car...
david
good info veetid. I'm going to try and work on this.
Anyone downloaded from the INAV link?Originally Posted by Quattro-A4
Does this file include the additional information for the appearances on the map?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Originally Posted by veetid
good job
i know what ill be doing when i get home from work![]()
i was messing a little with the resource hacker. here it is with 300 % bigger zoom buttons:
Someone figure out a way on how to move the positions around.
heres a before shot so you can see how small the buttons were:
It appears that it is centering the image. So make another image that is twice as tall as the one you are using now... Make it transparent and then place your new button at the top of your new tall image... This way it will visually raise the button on the screen because of the empty space below the button... It might work...
david
