Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
Thread: GPS Mouses....$30 to $200?
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    What's the difference between a $30 GPS mouse and a $200 GPS mouse?
    Will I, running a carPC based GPS system, notice any difference between the two? Will the $30 option suit my purposes as a normal driver just fine?
    Jul 2004
    brand names would help greatly for an accurate comparision
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    I have the same question. I believe the $30 units he refers to are the ones that "gps4evyone" sells on ebay. I believe the brandname is ratida or something like that. I was going to buy the earthmate unit, but after seeing these I was considering one of these. A quick search on ebay for "gps usb mouse" will return tons of results for gps units that go for $30-$50.
    PC Components:
    My work log
    Constant Bitrate SuzukiAerio's Avatar
    Aug 2004
    PA, USA
    Quote Originally Posted by Peoples
    I have the same question. I believe the $30 units he refers to are the ones that "gps4everyone" sells on ebay.
    This is all you need - I bought mine off that guy and it works fine !
    love it ...most of the differences are the "cold start time" ...in other words how long from when it first gets power until it gets a lock on some sats ....
    if you are plugging it into a ATX mobo ..then it will alwyas have/lock anyway (even if the car is off)
    ......Rikaline GPS 6010 that GPS4evrone (sp?) sells on ebay are just FINE !!!
    2002 Suzuki Aerio Sedan ...NOT the stupid wagon
    Nov 2004
    Michigan
    I would recomend the Rikaline 6010, cheap and work great... whichever gps you choose make sure that it is waas enabled
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I like my earthmate. Has very good cold-start times.
    VENDOR - Centrafuse veetid's Avatar
    I use to use earthmate, but didn't work out well for me... My car requires my receiver to be outside and the earhtmate will leak in every which way... The cable connection on it is designed poorly in my opinion also... I also like running serial instead of usb for a gps... 25 extra bucks for that earthmate calbe, putting you sometimes around the range of a total of $140.00. I just went with a Holux GM-210... Lots cheaper than the earthmate and lots better... Very rugid solid design, sealed every which way... All weather proof for mounting outside in any condition... Great cable system with every type of cable you can image, most time you get to choose which one you want for free.. Also the base is super magnetic for sticking to the roof of your car... It comes with an interneral battery to keep the signal locked to increase lock time speed... I paid 60 bucks for my GM-210, which ran circles around my earthmate in every way... I just wish I would have researched before I bought my earthmate, which now sits in a closest...
    my 2 cents...
    david
    Jul 2004
    Berkeley, CA
    You can get a used earthmate like me.. I got one that was weatherproof (rubberized) for $60 shipped, and another that was basically new for $75.
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    i have an Earthmate, and a Rikaline 6010 i have to say, that the rikaline is way better than the earthmate... earthmate: $80-$90. 6010: $40-$60.
    Lower price, beter service. go with the rikaline. I bought 3 of these (darn christmas season. hehe) from gps4everyone on ebay. best deals, and seller by far.
    go with the 6010, you will be satisfied...
    cheers
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by Skipjacks
    about $170.
    seriously though, cold boot times dont bother me because the 30-45 seconds it takes my computer to boot up, its already locked on at least 4 satelites. (the gps receiver locks independently from the computer. as long as its getting power, it'll lock)
    rebuilding carpc... kinda..
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 01:24 PM
  2. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 02:24 PM
  3. Replies: 9
    Last Post: 10-25-2004, 01:34 AM
  4. Replies: 12
    Last Post: 08-10-2004, 06:37 PM
  5. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 05:08 PM
