LAT/LONG + HEIGHT!!! Sweet for using as aimpoints for PGM's.Originally Posted by grepzen
Just got a 2K1 Denali and had to pull the carputer out of the jeep, but wasn't able to remove the GPS mouse from the roof... put it on too well, damn adhesive. I'll DEFINITELY be giving this thing a whirl.
2008 Ford Expedition EL Ltd
Carputer yanked from the Jeep and Denali and waiting to be installed in the Ford.
Nice information guys. Thanks for the links, I will be sure to look further into this![]()
OnStar started its switchover in 2002 so some cars have the correct modules and some don't. The easiest way to tell is if there are two boxes - one is the computer, the other is the cellphone used by OnStar. The newer modules are a single box with the GPS and cellphone integrated into the circuit board.Originally Posted by WakeBdr
No, some people just enjoy hacking stuff apart to figure out how it works. Reverse engineering can be fun sometimes.Originally Posted by Peoples
The GPS module used inside the older OnStar boxes is actually a Motorola GT Plus OnCore GPS receiver. Details are here - http://www.motorola.com/ies/GPS/products_legacy.html. I pulled the OnCore module out of an old OnStar unit I got from the junkyard and used a modified version of the first circuit on this site - http://neutrino.phys.washington.edu/~berns/K2K/TACGPS/ - to build an RS232 serial interface for the board. Its been working great ever since. I can post the modified schematic if anyone is interested.
I haven't been able to start this little venture yet, but it IS intriguing me more and more every day. I do have a question, though. In the 2001 Yukon, is the GPS antenna above the rear view mirror? And if so, how is the reception??? I know I had fits with my GPS antenna being inside my last car, so I moved it to the roof where it worked great. Next stop is finding the box to hack away!
I have a 2001 Tahoe, which I assume has the same setup as the Yukon. My GPS antenna is located right behind the rear view mirror, in the top center of the windshield.
The Onstar GPS antenna seemed to get a pretty strong signal. But I don't use it anymore, so I can't tell you how strong of a signal I received, compared with the signal from an antenna mounted on the roof. I can't recall ever having a problem determining my location or receiving a satisfactory signal strength, though...
It's not that complicated...Originally Posted by Peoples
Inside the Onstar box, plugged into a socket on the Onstar board, is a Motorola Oncore GPS module. This GPS module is used in other equipment, not just in Onstar stuff, and the pinouts are all labeled in the freely available Oncore manual.
So did you switch to an external GPS receiver then? And if so, did you mount it on the roof, and if so, did you just run the wiring around the third brake light, and if so... just kidding.The Onstar GPS antenna seemed to get a pretty strong signal. But I don't use it anymore, so I can't tell you how strong of a signal I received, compared with the signal from an antenna mounted on the roof. I can't recall ever having a problem determining my location or receiving a satisfactory signal strength, though...
I bought the same Motorola Oncore unit off of ebay that is used in the Tahoe. It came with a serial interface board and an antenna, so I just used that one and hooked the original car antenna back up the onstar unit, so now my onstar light is green again... And I mounted the antenna on the roof, in front of the sunroof. The cable runs behind the sunroof rubber edge? (I don't know what to call it), then over the roofliner, then down the a-pillar, back behind the dashboard, etc...Looks good, though...
i have a 99 escalade that has onstar...i already bought the bu 303 and its working great..would i have to spend some money to get the hack to work? if so ill just stay as is..if not ill do it and sell my bu303
