Results 1 to 10 of 13
Thread: IGUIDANCE_ nag screen solution
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    IGUIDANCE_ nag screen solution here
    Ok, so now that im on vacation and have a little more time to work on things.
    Ive been trying to figure out a way to kill the nag screen on IGuidance.
    I know others have a fix for this, but i cant seem to get ahold of the files (broken links) that were posted long ago.
    So, i figured some scripting should be able to handle something simple like this.
    I downloaded AutoHotKey which is open source scripting engine, key mapper etc, etc, etc. http://www.autohotkey.com/ very cool program!!
    anyway, i have a working script that kills the nag window.
    this script will kill the nag window if you run the script standalone ie; not embedded in front end.
    script will work with CentraFuse embeded, just point it to the script file instead of iguidance.exe. Seems to take a while but it embeds it correctly.
    Frodoplayer dosent seem to like loading the script and you have to hit the gps button twice for it to embed properly. I think this is just a timeing issue that will be fixed in the new release which will make this script not needed anyway, but for the time being for everyone else.
    download the program from the link above and install it.
    copy this into a new text file
    Code:
    Run, F:\Program Files\iNav\iGuidance\iGuidance.exe
    WinWaitActive ahk_class #32770
    IfWinExist, ahk_class #32770
    WinActivate
    Send,{enter}
    Send,{enter}
    edit the path to iguidance to point to where you have it installed on your machine, and save it as nagscreen.ahk or whatever you like.ahk
    make sure the script is saved in the same dir as iguidance.exe or you will get errors
    You can also compile the script as an .exe file, but since the path may be different on different computers you have to compile it as a .exe yourself, but this step is not needed.
    enjoy and let me know if you have any problems, and ill try to help.
    Aug 2003
    Chicago
    also, with a little editing, this should work for any program that pops up a window, not just IG. all you need is the window name
    Aug 2003
    Chicago
    anybody actually use this?
    I tried it out in my car after testing it in the house and for some reason it didnt work, not sure why, but i rewrote it while in the car so if the above script didnt work for you, try this (more simple) one.
    Code:
    Send,{enter}
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I use iGuidance in FrodoPlayer...nag screen doesn't come up.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Aug 2003
    Chicago
    cool,
    at least some one found it usefull.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    NaviVoice has an integrated nagscreen remover
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    This is deffinately a good thing
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Skipjacks
    Yep You would be able to launch the nav from frodo unembedded, but frodoplayer seems to have problems with the command line parameters... I've told Frodo already.
    Dec 2004
    Baltimore, Maryland
    Quote Originally Posted by 0l33l
    I don't use a front end anyway. I'm just happy that the nag screen is gone, and now with autohotkey creating the mini program my GPS iNav icon is a speed limit sign reading 85MPH.
    Jul 2004
    Berkeley, CA
    Autohotkey? Mini program?
  1. Complete solution, COMPUTER, SCREEN +DVD player for your car!
    By wrxmaster in forum Classified Archive
    Last Post: 07-09-2004, 03:26 PM
  2. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 07:38 AM
  3. Common theme in LCD screens..
    By spectrumzz in forum LCD/Display
    Last Post: 10-28-2003, 04:37 PM
  4. Replies: 13
    Last Post: 07-02-2002, 11:54 AM
  5. Redant screen - widescreen, screen res, TV out???
    By Griffin_Dodd in forum General Hardware Discussion
    Last Post: 02-06-2002, 07:09 PM
