What COM port is it connected to and have you tried Hyper Terminal on that port to see if it's dumping data?
Hey all-
I searched the forum but couldnt really find anything that pertained to my problem. I recently purchased an earthmate serial gps off of ebay, it came with the delorme street atlas 7.0 software and map and go or something. I hooked up the gps to my carpc(m900, 256 mb ram, 2.5" 1.3 gig hd, slime line cdrom, 60w morex psu, lilliput touchscreen, usb keyboard). I cant seem to get the gps working with Ninjamokeys destinator program(my uncle has destinator for his laptop/gps and I took the maps for my area) I cant seem to find the gps or the earthmate, and when I look at my system resources it shows a device found but not installed. Any ideas on howto get it working? I havent installed the street atlas software since it takes up more hd space then I can supply for it. I have installed it on my mothers computer though and it finds the gps fine. Hrrrmmmm thanks in advance for all the help!
-matt
I actually just got done installing the delorme street atlas software that came with it, and it was able to initualize the gps and actually get some locks and work. So I guess now I should rename the thread "How to get earthmate working with ninjamonkeys frontend without streetatlas crap there"But to specificly answer your question, no I havent treid that, but with the results of the installation and test software I think it's pretty clear it works. grrr. thanks for the help though, any other ideas?
-matt
edit: I didnt really answer your question, sorry, its hooked up to the serial port and I had the software on auto detect, both programs to be exact, and no I havent tried hyperterm yet, I have no idea howto.
If you got it working with delorme's software then you installed the drivers wrong. There are two settings when installing the drivers, the one u chose didn't install the USB->Serial driver needed for D3.Originally Posted by mattdisaster
but if it's a serial GPS you shouldnt install any drivers at all, actually in order to get it working you might have to disable the Microsoft Ball mouse under device manager.
肚子笑痛了
S60 Install
0l33l-
I'm not using a serial to usb connector, its connected via the serial port on my motherboard, sorry for the lack of description.
jcdillin-
I'll have to check that out in a few minutes, I'm gonna go work on it again after dinner.
Thanks alot you guys for the help and interest in my problem, you never fail to let me down! I just hope I can get this to work, the delorme site doesnt really have any help on there aside for people using the usb version and the serial to usb adapter. Well anything other then, "install our software and be done with it" type of stuff. Wish me luck, thanks so much, just a thought what would I need to install for this to work with destinator? Maybe I should trying to install that from my uncle and see what happens. hmm
-matt
if that unit is serial you shouldnt have to install anything, just set either autodetect with destinator or set it to whatever com port you have the GPS connected to 4800Bps and NEMA
肚子笑痛了
S60 Install
you might have to have something 'initializing' it like the usb version
try gps gate
go for the beta version
http://franson.biz/gpsgate/
Update:
Well I finally tried as much as I could to get it working with NinjaMonkeys Destinator 3 frontend and have yet gotten it to find the gps. So heres what I've done:Any one got any ideas? I'm stumped and really dun wanna get stuck using Street Atlas. Thanks so much guys for all the help so far. I'm totally stumped now.
- I've installed Delorme Street Atlas 7.0 and it finds the gps hooked via the only serial port on my via m-900 motherboard. It finds it via autodetect though, and I havent been able to find out what its settings actually are.
I've installed the frontend and copied over the maps from my uncles install of Destinator.
I've tried to have the destinator 3 frontend find the gps and it cant seem to locate it.
I tried the gps gate program mentioned above in the thread and couldnt get it to find the gps ither.
And I dont have hyperterm installed on my carpc system since I didnt install it with nlite.
Still in the device manager theres a device listed as "unknown device" that goes away when the gps is removed. And from what I can tell there arent any drivers for the gps unless its a usb one, which it isnt.
-matt
It sounds to me like that unknown device is screwing things up. What part of device manager is it listed under? Double-click on it. What does it show for drivers, if there are any or under Details does it show anything for instance ID or hardware ID? That's a very odd thing. I would think it's safe to uninstall or at least disable.
