Results 11 to 20 of 27
Thread: GPS off by about 50 ft
  1. #11
    Jan 2004
    Jersey/NY
    I think I know what you mean by upside down... i know with my receiver (bu-303) upside down KILLS the reception.. but hey try it, may be different for yours.
    An easy way I mounted mine was hot glue gun.. just make sure not to put hot glue onto tint or anything like that, you may ruin it if you tried to take it off.
    Originally I tried velcro, but the adhesive didn't hold up... the hot glue gun method, strong as nuts.
  2. #12
    Constant Bitrate SuzukiAerio's Avatar
    Aug 2004
    PA, USA
    I am sure your problem is the amout of SATs you have locked magnetic mount it on the roof and see what ya get - I bet it will be better
    I have a Rikaline 6010 receiver and have no problems with it on the rear dash
    hint - get some velcro and put only the HARD side on the bottom of the GPS, it will stick real good to that "carpet" in most rear dashes - also get velcro (both sides) and try your upside down theory - I have thoguht about putting it upside down but havent had a chance- let us know how/if it works
    2002 Suzuki Aerio Sedan ...NOT the stupid wagon
  3. #13
    Quote Originally Posted by legend5761
    Hey, I just took a trip to LA with mine and mine is off about 100 feet. I have a Rikaline 6010 receiver, clear view to the sky. I don't know what is wrong.
    my problem is like wtf....i'm using earthmate usb with iguidance 2. The visual navigation is pretty damn close, maybe only 5-10 feet off, but when i hear the voice navigation it's off by like 100 feet. What gives?
  4. #14
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by bobthebaker
    Then its not the earthmate's fault. iG will talk when it feels necessary.
    Also, my earthmate isn't off by very much at all
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Skipjacks
    It's on the rear shelf under the back window. Pitcures are available in the link in my sig line. Think that could be a problem?
    I have a BU 303 and it is on the back shelf in my car, get normally 7-8 sats, occasionally drops to 5.
  6. #16
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    maybe it's a goverment conspiracy thing, since they can shut down the sattelites to their liking... you never know...
  7. #17
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    I have noticed that my BU-303 only gets 3 or 4 sats when on my dash but gets 7 to 9 when placed inside my sunroof. It seems to be because of the metallic film they use when tinting windscreens, even though my sunroof has a sort of metallic feeling film with millions of small round holes in it to darken it, it doesn't affect the GPS signal whereas the windscreen does.
    It might be worth sticking your sensor out the sunroof or a window just to see if it improves.
    Using SirF mode as opposed to NMEA also seems to increase positional accuracy and update speed if you are able to use it.
    HTH
    John
  8. #18
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Most GPS units have a position update rate of once per second. At 45 mph, your car will travel 66 feet in one second. Your mapping software will always display the car symbol one second behind the actual position, unless it can do dead reckoning. The left/right position would not be affected.
  9. #19
    _
    Mar 2004
    Little Elm, Texas
    My GPS, running i Guidance with an Earthmate receiver seems to be about 50ft off. It's got left and right fine, but stright ahead is off by about 50ft when I come to an intersection. It'll tell me to turn in 50ft, when I'm already at the intesection.
    Is that just the nature of hte beast or do I need to adjust something?
    could it be the earthmate reciever? I have the earthmate reciever and software (though I don't use it anymore in the car) and I noticed that I was off quite a bit as well.....though the software didn't snap to teh road.....
    wondering if the reciever might have something to do with it?
    Jan Bennett
  10. #20
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    i have a earthmate as well with iGuidance and the position is pretty much dead on unless im dropping sats, but thats another problem.
    what gps software are you using?
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  2. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 03:24 PM
  3. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  4. Replies: 36
    Last Post: 04-13-2005, 05:03 AM
  5. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
