Results 1 to 10 of 16
Thread: extend GPS antenna??
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Can u extend a GPS antenna. for example i would like to hide the gps mouse, is i possible to extend its antenna through a wire out of the vehicle (something like a radio receiver). has anobody got internal pics of a GPS mouse/receiver??? Would like to see what the antenna looks like
    Aug 2004
    Newcastle UK
    i guess yeah you can if you had high enough quality components but considering the amount of signal is so so so weak that you receive, you'd need some pretty damn good cable and high quality solder to get it working as well as it can do - also from my gps (bu 303) the antenna is pretty much hard soldered to the pcb and is the largest thing in the shell, instead, make your mouse water proof and stick it outside
    MII10000; 512MB RAM; 7" Lilliput Touchscreen; 400watt Muttant AMP; Wireless pc start (keyfob); WiFi; GPS with D3 NM Front End; MediaCar; 40gig 3.5" HD; In-Dash mounted tft;
    Sharjah, Emirates
    thanks for ur reply..... i guess so, i will have to waterproof it.
    Newbie Dirk9N's Avatar
    Jul 2004
    Germany
    maybe you can find an Idea in that Forums threat, there they build in an GPS reciever into an VW Triplex antenna. I builde on into an Audi Triplex antenna. great revievment (9-15 sats permanent)
    noone can see them, they are waterproof ... perfekt solution
    Apr 2002
    Houston, TX
    Quote Originally Posted by Dirk9N
    Sounds like some useful information, could you supply the name of the forum you mention or a link....
    I hope it ain't this forum or I will feel like a smuck
    Jul 2004
    Germany
    thats strange, i added a Link last time, where is it gone?
    here its again:
    http://www.car-pc.info/phpBB2/viewtopic.php?t=639
    It's an german Car-PC Forum.
    I don't know when, but within the next time I want to "rebuild" my antenna, because my GPS modul was much to big, so I had to remove the whole Radio and Cellular antenna - part. thats now in the car. I added an Wire at the Antenna contact, and tgough the cartop, to the external electronics (hope that works)
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Could you explain what you did to the receiver for those that don't speak german. Thanks.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Jul 2004
    Germany
    I try, but not today, ok
    Dec 2003
    New York
    No problem, I tried babel fish but the translation didn't make much sense. Thanks in advance.
    Installed
    Sharjah, Emirates
    we'll be waiting for the english writeup.
    thnx for ur replies.
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  2. extend GPS antenna??
    By ramy_zohair in forum GPS
    Last Post: 01-09-2005, 10:12 AM
  3. Replies: 11
    Last Post: 12-06-2004, 04:48 PM
  4. Gps Module + External Antenna + Waas + Usb
    By e_z_street in forum GPS
    Last Post: 10-06-2004, 04:57 PM
  5. Hacking GPS: External Antenna?
    By dubwise in forum GPS
    Last Post: 07-04-2004, 06:36 PM
