Results 1 to 9 of 9
Thread: Microsoft Streets & Trips 2005 w/GPS Locator
    GPS RECEIVERs in Canada
    anyone have any good inputs on what works good in Canada?
    I search and the only result I got was the Garmin GPS35PC anything else?
    Nov 2004
    NY tri-state
    I'm not sure I understand... ANY receiver should work equally well just about anywhere on Earth -- it's the premise being GPS. The issue is not the receiver, but the software itself. If it doesn't come with decent maps for your location, then it's gonna suck.
    I'm not sure how detailed the maps for MS Streets are for Canada, but I do have the software. If you want me to check out a particular area and take a screenshot or something, let me know.
    Low Bitrate jay_tu's Avatar
    Dec 2004
    Towson
    Quote Originally Posted by viguera
    Hey Viguera:
    I got MS S&T 2005, cant figure out how to make it interactive for directions, or is it even possible using MS S&T 05 ? (Have it connected to an external gos that tracks my location just fine)
    By interactive I mean for it to give me directions for a certain location ? Like make a left turn after 0.25 miles etc ? Can you share your experience ,
    thanks
    jay
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by jay_tu
    Hey Viguera:
    thanks
    jay
    You need to use the route planning feature..
    Dec 2004
    Towson
    thanks... will check it out on my way back
    Dec 2004
    Towson
    it shows directions in text, like from mapquest, but wont indicate what to do???
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    From what I understand MS S&T 2005 does not have voice prompts.
    Oct 2004
    S&T does not have voice prompts, and I don't believe it has big arrows pointing which way you should go either, which is probably why everyone prefers Routis, iGuidance, D3, Copilot, etc.
    Edit: I was OK in the beginning with following the green line in S&T. It even led me to a White Castle once =)
    Dec 2004
    Towson
    thanks for the input, helps a lot to reach the conclusion that S&T is not the right thing i want.
    Now the question is which one do i try next, dont want to end up spending 200 on the software..
  1. Microsoft Streets and Trips 2005 w/ GPS
    By ecaandrew in forum GPS
    Last Post: 01-08-2005, 01:22 AM
  2. Replies: 29
    Last Post: 10-22-2004, 09:58 AM
  3. Replies: 1
    Last Post: 10-01-2004, 08:02 PM
  4. Replies: 2
    Last Post: 08-23-2004, 05:12 PM
  5. Microsoft Streets & Trips or Mappoint??
    By allinc666 in forum GPS
    Last Post: 02-26-2004, 12:10 PM
