No, but if you have enough room for it there it should be fine. Just make sure it doesn't get too close to the brake light if it's an actual bulb because they heat up quick. If LED's, no problem. If it's a rear hatch door that you're talking about, I'd mount it securely with some kind of shock absorbsion like some foam to protect if from when the door slams shut.
LinkBack URL
About LinkBacks
if i'm remembering right, his high mount brake light is mounted in a sort of fiberglass "bubble" on top of the rear roof. his back door is not a hatch like yours - it's got a rear window that rolls down, but the rear glass rolls down into a tailgate that opens just like a regular pickup truck.
