Results 1 to 10 of 10
Thread: is there a way to take a compact flash GPS to USB?
    Oct 2004
    South Carolina
    delete this thread
    I have a compact flash GPS. It came with an adapter to take it to PCMCIA. It's made for PDA's or Notebooks, it came with drivers for all.
    I got a notebook motherboard from compgeeks.com a while back when they were liquidating them. I popped a p4 2.0ghz cpu in it, and it's blazin.
    I want to turn this into a carPC, with 5" LCD and all. I want to tie the GPS into it.
    Will a USB Compact Flash card reader be able to run this GPS? Is there any other way I would be able to use this GPS in my system?
    Thanks for any info!
    -Matt
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    Doubt it. The laptop motherboard didn't have the PCMCIA slot???
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by strohmrs
    I bet it has the plug for it, the header or whatever, but the actual slot part was probably not included. They are usually removable from the mobo.
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    I found a PCI to Compact Flash adapter that will run your GPS thingy, but nothing USB that will support...
    Tidder
    Try RevFE
    Oct 2004
    South Carolina
    there is no pcmcia slot on it, I'll have to check for the headers and see if I could add the slot to it. nice suggestion
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    USB GPS are really cheap.
    There are USB --> CF adapters, but I feel like that wouldn't work.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    i'd sell the compact flash gps on ebay and get a USB one you can mount in your window.
    Oct 2004
    South Carolina
    well ... my train of thought is this...
    in all retail computers, the card readers on the fron of the computer are actually plugged directly into a USB port header on the motherboard. I'm curious to know if this kind of setup would work.
    I'll go to circuit city tonight and test it on one of their computers
    Mar 2004
    Bristol
    most of the time those card readers only support storage devices but it is worth a try i guess.
    Oct 2004
    South Carolina
    ok I think i'll do that. Do you have any suggestions on a great USB GPS?
    I got this GPS off ebay for under $100. I was originally going to use it between my PDA and my laptop (which both had onboard CF headers, and they both worked fine..)
    but since, my PDA has died, and I wanted to build my carputer ... so i'll make the switch
  1. Bluetooth Compact Flash Card
    By biglips31 in forum Input Devices
    Last Post: 11-04-2004, 04:30 PM
  2. lilliput kills USB GPS
    By johnymd in forum LCD/Display
    Last Post: 10-07-2004, 02:42 PM
  3. FS: Delorme USB GPS
    By xizor in forum Classified Archive
    Last Post: 10-07-2004, 01:33 PM
  4. Usb Gps
    By nibix in forum GPS
    Last Post: 06-01-2004, 02:31 AM
  5. Replies: 2
    Last Post: 05-27-2004, 11:01 PM
