Results 1 to 7 of 7
Thread: Are all GPS Receivers the same?
    Jan 2005
    As the topic states, I am wondering if all GPS receivers are the same? I am just looking on EBay and there are about 4 or 5 different manufacturers and I am not too familiar with all the specs that GPS goes by. I am looking at GPS USB receivers if it makes a difference. Any guidance, suggestions or help is appreciated.
    Is there anything in particular that I should be looking for?
    I would search but I am not sure what it is (terminology) taht I should look for in order to find good/informative results.
    Suggest any search criteria and I will definitely look some info up.
    Thanks guys/gals
    J
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Not all are created equal.
    Jan 2005
    Bump up because I am not sure what I should look for if I were to search or what criteria I should use to qualify a GPS receiver.
    Any help is appreciated
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    They're all *relatively* the same. There are different chipset revisions. Try to do some research at gpspassion.com to see the differences in some chipsets/devices. Also, look at semsons.com to get a taste of the different gps devices available.
    -HD
    Jan 2005
    Thanks very much for the guidance. I appreciate it.
    Cheers
    J
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    I dont agree - The theory is all the same, but the more expensive units have many additional reafutres...
    Pay attention to Lock time, for a 3d lock. time to lock from cold / rest
    I have used a cheap one, and Im very with my investment in a quality unit.
    Then again, if its only occasional use, and you dont mind the wait, the 45-75 range will do fine.
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    <> Number of channels are climbing from 12 to 20
    <> Some now have all the features of a handheld gps AND the ability to connect wired/or wirelessly to your PC/PocketPC/Palm.
    <> Just a matter of time before DeadReckoning is standard
    <> Some record the last 30,000 points for path/rout retrieval.
    --- yeah, they're not all the same.
    Either buy cheap now and plan upgrade if you want features yet to be fully developed. --Or spend some cash now for a unit that will suit your needs for the term.
    I just got a Holux GR-321 that is pretty nice.
    ∙ Quick locks,
    Bluetooth AND USB
    ∙ Battery or cable powered
    ∙ Port for ext antenna
    ∙ SiRF and NMEA compliant
    •Micke
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  2. Replies: 6
    Last Post: 03-16-2004, 03:03 PM
  3. GPS Receivers
    By streetknight in forum GPS
    Last Post: 02-28-2004, 07:19 PM
  4. Popular GPS Receivers
    By bambooracer in forum GPS
    Last Post: 02-27-2004, 04:08 PM
  5. PC-35 GPS receivers
    By craigyb in forum Classified Archive
    Last Post: 09-16-2003, 01:39 PM
