Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Possible? Run two gps applications at once
    Super Moderator xBrady's Avatar
    USA
    Is it possible to run two GPS applications at once? I was about to start on a small application that uses the com port your GPS is on to grab info every once in awhile and I don't want it to interfere with the already running navigation system.
    Is it not possible to read from a com port from two seperate applications?
    Installed.
    -GPSSecure- - GPS Tracking
    Variable Bitrate nottastocker's Avatar
    Jun 2003
    Shenandoah, VA
    I don't see why not, it seems that NMEA protocol is a passive one... but then again, I have never personally used a gps system myself.
    Jun 2004
    Central California
    Give this site a browse: http://curioustech.home.insightbb.com/xport.html.
    I use an OEM GPS receiver (Garmin GPS25LV) which has two com ports. Probably you want to invest on one of those.
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    FLAC ppgt94's Avatar
    May 2001
    USA
    You'll need a software (or hardware) com port replicator. Do a search for one on the forum. I have a freeware version that works but I forget what it's called.
    *edit* edik beat me to it. That's the one I use.
    Maximum Bitrate dodgetimes2's Avatar
    MI
    GPSGate maybe?
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Low Bitrate Vacheron's Avatar
    Jan 2005
    Newcastle UK
    Quote Originally Posted by dodgetimes2
    GPSGate maybe?
    I'm using GPSGate to run 3 GPS applications simultaneously. (Netstumbler + 2 Navigation packages) and it has worked perfectly on XP ever since I intalled it. Two thumbs up from me.
    Jan 2004
    Sydney
    Maybe you should consider this bluetooth receiver from Emtac. I know its bt and runs on batteries and costs more, but it is capable of connecting to 4 devices simultaneously via the bt virtual com ports straight out of box.
    http://www.gps4fun.com/trc_bluetooth_trine.php
    I have one of the earlier ones (without multilink support) and it works like a charm always!
    USA
    Thanks for all of the information guys! I probably wouldn't go for getting a new GPS device as the application I am making will be released to forum members and I don't want everyone that uses it to have to get a new GPS module If all it requires is an external application then that will work for me. I'll try one of those two apps and get started right away on the programming.
    Installed.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Just use this one http://curioustech.home.insightbb.com/xport.html post earlier.
    Work wonder and it free from our own memeber Curiosity
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Yes?
  1. Gps Diagnostic
    By 4u2n in forum GPS
    Last Post: 09-06-2007, 03:01 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  3. Newbie's guide
    By EBFoxbat in forum Newbie
    Last Post: 02-08-2005, 11:06 AM
  4. why does my taskbar show when i run gps???
    By TheKurbster in forum FrodoPlayer
    Last Post: 11-10-2004, 09:36 AM
  5. Triggering events based on GPS location
    By electron in forum GPS
    Last Post: 09-16-2004, 12:57 PM
