Page 3 of 10 FirstFirst 12345678910 LastLast
Results 21 to 30 of 98
Thread: BU-303 ! I have found the problem for all!
  1. #21
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    I have suspected something like this for a long time...
    I found that if the BU303 is left for a few weeks it took me ages to get the satellites to lock, until days and days after hooking it back up - and it had reset from SIRF or whatever back to NMEA 4800.
    I just figured the battery needed time to warm up.. I'll be trying this for sure though!
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  2. #22
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Quote Originally Posted by westscape
    Well last time I looked I was sure the "battery" inside the BU-303 is not a battery but is actually a super capacitor. Not sure what soldering a battery in would have though!
    I'm almost positive it's a battery, not a capacitor. Anyone wanna back me up on this?
    CarPC install is starting to come along again...
  3. #23
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    I popped open my BU-303 to check out this "watch battery". Actually it is NOT a battery, but a 0.22F capacitor ("SuperCap"). Think of a supercap as a small rechargeable battery with a very short charging time. Replacing it by a non-rechargeable kind of (watch-)battery is definitely a bad idea.
    Older BU-303s are known to contain badly soldered or otherwise badly mounted supercaps which come loose due to a car's vibration. This might be an explanation for the problems you guys are having.
    Should the BU-303 have contained a regular battery, the manufacturer would have mentioned so, or would at least have made it user serviceable.
    - Erwin
  4. #24
    May 2004
    Arkansas
    Interesting. So I didn't know capacitors started going bad like that. Any insight on where to get one? I don't think I need one, since I still have my old one, I'm just asking for anyone else. Mouser.com or Digi-key.com? I just searched and it looks like they have some specifically labeled "super backup capacitors" that have the specs we need for a minimum of 1500.
    Mox (or anybody) would a typical .22F electrolitic cap with a max voltage rating of like 35 work?
  5. #25
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Grayscale
    Yeah caps can die with a lot of use - especially high capacity ones like that.
  6. #26
    mox
    mox is offline
    Nov 2004
    The Netherlands
    I guess so, but don't expect to find a .22F/35V capacitor that will fit. Remember, .22F is 220,000 microfarad!
  7. #27
    May 2004
    Arkansas
    Quote Originally Posted by mox
    I know, it took me a sec to figure out why you were calling it a supercap and then I was like OH, its not 22uF! Well I guess I'm safe for now. So putting a watch battery in would be bad...hmmmm. I will have to test out if putting my "SuperCap" back in will make my GPS lock faster.
  8. #28
    Constant Bitrate naveedh's Avatar
    Oct 2004
    ok looking on this advice, my Rikaline 6010 started playing up as well. So i thought i open it up and had a look and it is a battery. If you search for PCB mounted batteries you will find what your looking for, i have. The price i found was $4.
    The Rikaline Has a Battery not a supercap.
  9. #29
    Jan 2005
    Couldnt you just use a 12v to 3.3 LDO regulator from the car battery to where the cap went. Then you would always get a quick satalite lock.
    Of course you would need a diode on the output so the gps doesnt try and charge it.
    Obviously you would have to look at the circuit to see if its possible, but its an idea
  10. #30
    Constant Bitrate Goddy's Avatar
    Dec 2004
    Netherlands
    To avoid all these bu303 problems (there are also problems with this gps unit in combination with lcd-screens) are there any good alternatives? I have the bu303 too and i have to put the unit on the airbagunit (it has a metal underground) so the lcd wont interfer with the gps unit (i have tried all Hz', none working fine).
    Is the Rikaline a good alternative?
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  3. GPS not found problem
    By ThEScReW in forum GPS
    Last Post: 12-20-2004, 06:39 PM
  4. Noise problem -- finally found the source!
    By sq_geek in forum General Hardware Discussion
    Last Post: 11-15-2004, 12:49 AM
  5. Found and fixed another Lilliput problem...
    By Altimat in forum LCD/Display
    Last Post: 01-01-2004, 10:16 PM
