Page 9 of 10 FirstFirst 12345678910 LastLast
Results 81 to 90 of 98
Thread: BU-303 ! I have found the problem for all!
  1. #81
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    I guys, I screwed my brand new navilock and are using it without the cap for a while now. some times it takes longer to get a lock but after that no problem at all.
    check these 2 pics:
    Navilock Inside 1
    Navilock Inside 2
    on the second one you can clearly see a + and - mark. I guess you can use those for a larfger cap pherhaps.
  2. #82
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Tip when soldering your new battery on... watch your fingures - the battery gets real hot real quick.... I now have an imprint on one of my fingures now lol.. will go in a while..
    Terran
    PS I'm used to doing this stuff - took about 3 secs to heat up.... Owwww !
  3. #83
    Jan 2003
    PS Can some one advise what the proper battery code is. Its very simular to another 'watch' battery but they are 1.5 as a rule...
    Any direct suppliers in the UK would be good as I used a 3v replacment for the mo...
    Terran
  4. #84
    Constant Bitrate chuckctv's Avatar
    Aug 2004
    Virginia
    look everyone, (battery/ super cap?)- doesnt matter... *I originally started this thread 3 months ago, and i guess i never came back to it.. *SORRY*. But in any case,
    when your BU-303 Gps starts to fail- just open it up (2 tiny screws on bottom under the rubberpad), and find the battery/supercap thingy *looks like a small watch battery and says 3.3volts on itlike a watch battery also*, and RIP[I][U] it out (it should be safe and not harm the unit), then put it back to gether and it will work just fine, it will take 30 more secs(roughly) to lock on *in the beginnning only* and you didnt need to buy a new one at all. mine is working fine 3 months later.
    chuck
    www.XionElectronics.com
    **MY NEW STORE** Come Visit
  5. #85
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by chuckctv
    chuck
    That's how I understood it.
    I've ripped the battery/supercap thingy out of mine.
    Before I did it, I was going maybe an hour without lock at it's worst - it was terrible, and through a city it was useless. I went for a country drive and actually got LOST because it couldn't find a lock.
    Since I've taken the battery/cap OUT COMPLETELY I have never had a problem. My GPS lock issues have dissapeared!
    Finger crossed, anyway
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  6. #86
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    my bu-303 wasn't working right etheir so then I put it on a metal surface and it worked just fine. I think the magnet needs to be on a metal surface, I can't explain why but those are my findings.
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  7. #87
    Constant Bitrate grum's Avatar
    Feb 2005
    australia, melbourne
    Quote Originally Posted by mbkowns
    if you read previous pages, its to do with antennae theory, large ground plane single dipole etc. etc. do a search of maxwell . im sure youll bore yourself in 5 minutes, ive been doing this for 5 years, you can imagine how over it i am.
    CarPC Status:
    Hardware: 100%
    Software: 100%
    Case Install: 100%
    Dash Install: 100%
    Car Install: 100%
    crap factor: 100%
    new carpc finished, thinking of way to mount HDD
    and not installed yet.
  8. #88
    Nov 2004
    NYC
    After almost eight months, my gps mouse crapped out too. It would barely keep a lock and was taking forever to even get the first lock.
    For those that have the Rikaline 1060, I had to use Visegrips to open mine up. It didn't have any screws along the bottom, something I found out after peeling away all of the glue. The housing had four clips; two along each of the long sides and was glue to boot. After I got the housing off, I found that it was enclosed in another metal housing. I carefully pried open the lower half of the metal housing and found the battery/cap somewhere in the middle of the PCB. Be very careful when removing the battery, since the way mine was wired, the metal housing had the ground wire soldered on to it.
    After putting it back together, I checked to make sure it would still turn on and plugged it into my carPC. Took a little bit longer than I can remember to get a lock, but I haven't driven around yet to test.
    As far as the battery/cap argument goes, it seems like all gps mice are not created equal. Mine had an SMP backup battery and not a supercap.
  9. #89
    Nov 2004
    NYC
    Rikaline 1060
    Ok........ So I guess taking the battery out had no fookin!!!! effect on a lock. As long as the car is not moving, the damn, POS gps mouse can get a lock. As soon as I move, it loses the lock.
    On the first try after taking the battery out, it took mouse an hour to get a friggin lock with the car moving. I'm certain that it has nothing to do with the location, since I had it in the same place for the last four months without a single hiccup. Since I've already taken it apart, I'm going to try and solder a watch battery holder to the mouse and use a 3.3V watch battery.
    Will keep posted with the results.
  10. #90
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    I have an old Deluo GPS (with some form of Evermore chipset in it). I took to it with a screwdriver and a Leatherman yesterday, and ripped the battery/cap style thing off the board. It was not a delicate operation.
    Reinstalled the drivers, locked first time.
    The magnet that is in the base of mine has no connection with the circuitry inside, and as it's sitting on the dash, there is no metal for it to en-magnetise-ify with, so I can't offer any feedback on that front.
    Sweet.
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 02:57 PM
  3. GPS not found problem
    By ThEScReW in forum GPS
    Last Post: 12-20-2004, 05:39 PM
  4. Noise problem -- finally found the source!
    By sq_geek in forum General Hardware Discussion
    Last Post: 11-14-2004, 11:49 PM
  5. Found and fixed another Lilliput problem...
    By Altimat in forum LCD/Display
    Last Post: 01-01-2004, 09:16 PM
