As TV-frequency is nowhere near Radio/GPS frequencies, it won't improve tv-reception at all.
So this antenna supports FM and GPS? I wish it supported XM too. I wonder where the antenna is as a factory option on the 2005 models. I would be really nice to consolidate all the antennas into a single factory antenna.Originally Posted by VWmike
Thanks for all the info Mike. I don't have to worry about crimper and cable etc as I have them all at work and I make RF cables all the time. Thanks alot of the part number on those connectors though. I would order an antenna from impex but they are don't like to ship to canada and their prices seem to be getting higher and higherOriginally Posted by VWmike
Man - I wish you still posted here VWmike!
Unfortunately the link to the first cable is bad (it was an ebay auction...)
Anyone have any more info on this cable?
edit
ok - I've done a bit more reading and searching, since I'm not using a case, I don't need to worry with the BNC connectors. So this leads me to my next question. What kind of connection is made to the card its self? Is it a MCX connection on the card and at the antenna? If I'm seeing it right, it appears that the reciever has a female connection built onto it, so that end of the cable needs to be male? What about the antenna end? Male or female? I'm thinking that this cable would be what I would need but I'm a little unclear. Anyone? Link to cable
Also, regarding the mention of the connectors:
P/N FA1-NCRJ-C01-0 / GPS
Is this because the antenna only comes with ONE end and you need to buy the other?
I'm not worried about the FM part of this just yet. If I can find a decent FM card, I would be happy to utilize that part of the antenna as well.
Jan Bennett
I know that you said you made one of these cables. I'm trying to figure out exactly which one.Originally Posted by jcdillin
Is it the one that goes to the serial port?
Also, I'm trying to understand why you went to a serial port on the back of the machine that leads to nothing instead of going to a serial port actually on the mobo. Or did you just tap into the serial port back there instead of going to the mobo directly?
Thanks in advance!
Jan Bennett
PS: if anyone is interested, I've found the antenna listed for right at $100 on this site:
https://www.1stvwparts.com/part_number.html
Just search under the OEM part number: 1K0035507C
Jan Bennett
Spiffy SiRF III module: http://www.sparkfun.com/commerce/pro...roducts_id=652
I'd buy one if I hadn't already bought a Garmin GPS 15H. Ah well, when the time comes to replace it there will be GPS/GLONASS/Galileo combo units on the market![]()
System status: in progress
so what's different between that module and the Garmin?
I notice that it only has a 110v power supply....wonder if the wall wart is just converting it to 12v? or if the unit takes 110V to begin with?
and I'm gathering that since it's an eval version, it's still in beta mode?
can you go into a bit more detail about the GPS/GLONASS/Galileo units?
What is special about those? I'm gathering it's more sensitive? more accurate?
Jan Bennett
The SiRF III chipset is what's being used in some of the newest Garmin GPS receivers (like the GPS60Cx), it's a 20-channel WAAS-enabled receiver with better sensitivity than the Garmin GPS15H/L (-159dBm for the SiRF III, -135dBm for the Garmin) and ever so slightly less power consumption (.23 watts vs .33 watts...not enough to make any kind of difference in a vehicle).Originally Posted by Red GTi VR6
Most likely takes a range of something like 9 to 15 volts. Take a look at the board, all it has is a linear voltage regulator , TTL->RS232 level shifter, and the GPS module.Originally Posted by Red GTi VR6
No, it's in production. The eval board is just that...for people to evaluate the unit and decide if they want to use it in their products/projects. My previous GPS, a Motorla M12 module, came on an eval board. Usually all the eval board does is provide power regulation, TTL/RS232 level shifters, and an antenna connector so it's easier to experiment with. Difficult to play around with something when it wants 3.3v and spits out TTL on a tiny pin header.Originally Posted by Red GTi VR6
Galileo and GLONASS are other satellite-based positioning systems. GLANOSS is Russia's system, Galileo is the European Space Agency's system. See:Originally Posted by Red GTi VR6
http://en.wikipedia.org/wiki/Galileo_positioning_system
http://en.wikipedia.org/wiki/GLONASS
A receiver that's able to make use of more than one positioning network will be a bit more robust and accurate.
That antenna is actually only about $80. I got mine directly from Germany for only $80
