Results 21 to 30 of 39
Thread: Earthmate not locking
  1. #21
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by albysure
    i have an earthmate with street atlas that came with it. i just tried it agagin and it wont get a fix or show up in device manager. i had a rand mcnally receiver that did work but that was serial and i wanted to go with the usb receiver. app was streets and trips and it work fine through the windshield. might have to go back. and...i put the earthmate receiver outside the car and waited for quite awhile and no go. when i plug it in i get a flashing red light for about 3 or 4 times and then it goes out.
    What model Earthmate do you have?
  2. #22
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    usb earthmate
  3. #23
    Dec 2000
    pittsfield, ma.
    and it is not on a hub thanks!
  4. #24
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Did it ever work. What has changed. I am starting to think that the unit might be defective or broken. I think the LED should stay on, either flashing or steady. I don't think it should just run off. THat sounds like it is losing power and/or shutting off.
    Michael
  5. #25
    Dec 2000
    pittsfield, ma.
    i bought it around december and just recently teird it out. i think at one point the light stayed on steady. i will try it again tomorrow. if not i guess ill go back to my old one-a rand mcnally streetfinder deluxe-which did work through the windshield
  6. #26
    May 2005
    Herts, UK
    I have a Evermore USB receiver which worked great with my Laptop. Since connecting it to my Car PC I have hade much poorer results. Initially it would pickup 1 maybe 2 satelites. I then reinforced the ground connection to my PC with a 10mm cable straight from the PSU cack to the car chassis. Now I get get a better result but still not good enough. I beleive there also may be an issue with PSU/ignition noise as the number of satelites seems to vary with engine speed! The receiver, being on the dash is close to the car electronics which may be causing some interference. The PC is mounted in the dash too. My next step will be to move the receiver to the back and also to scope the power rails (difficult while driving.!)
    Another factor these summer days (in the UK) is trees. I've found that the foliage in the suburban streets can reduce the satelite count dramatically.
  7. #27
    Aug 2005
    Do you have a laptop or screen in your car. I have the earthmate and it appears that on my system it's being interfered by the touchscreen software for the Xenarc 7" screen. If I turn off the screen for 30 seconds bam it finds the signal, if not then it has varying degrees of getting and dropping the signal.
    -mike
  8. #28
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Paisan
    -mike
    That would mean the screen is causing interference, not the Touchscreen software. The touchscreen software doesn't turn on and off with the screen. The software/driver remains "on" on your system, whether the screen is off or not.
    THe intereference is from the screen itself. You might want to try changing the refresh rate. I have heard that changing the refresh rate has helped other people.
    Michael
  9. #29
    Aug 2005
    Interesting. Today I'm going to try unplugging the USB port for the touch screen and see if that makes any difference.
    -mike
  10. #30
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    -mike
    Let us know.
    Michael
  1. USB Earthmate - patch for gpsd support
    By dignome in forum GPS
    Last Post: 04-05-2005, 10:44 AM
  2. FS: Targus DC laptop adapter, Earthmate w/ BT pack, Latitude C/Dock
    By kandyman676 in forum Classified Archive
    Last Post: 02-23-2005, 08:56 AM
  3. Earthmate GPS don't work...help please
    By Skipjacks in forum GPS
    Last Post: 01-01-2005, 11:20 AM
  4. Replies: 21
    Last Post: 06-30-2004, 01:17 AM
  5. Replies: 5
    Last Post: 01-04-2004, 09:43 PM
