Results 1 to 10 of 10
Thread: Question on OEM GPS modules
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Question Question on OEM GPS modules
    I am looking at ordering the Garmin OEM module. Does anyone know the difference between the 15H and the 15L? I would like to avoid soldering if possible as I'm not very good with those types of things. I would prefer the closet thing to plug and play with this mod.
    Thanks for the help.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    isnt the L low voltage or summit? and the H high voltage. You want the L i think
    www.maplin.co.uk has them i think if you want to check - that is were i seem to remeber reading it.
    Jun 2004
    Central California
    The difference is in the voltage requirement. Download its manual on Garmin's website for more info.
    Once you plunge yourself into OEM GPS module, soldering is pretty much unavoidable.
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    ddn
    ddn is offline
    Dec 2004
    The H and L are high and low voltage. Which one you want really depends on your application. HOWEVER, there are 2 different H and L models too, the "Flex" and "Wired". You want the wired, because the flex is a ribbon cable and imagine the hassle. Order from GPS City where it is clearly defined which is which.
    More than likely you should get a BU-303 or similiar though. If you don't want to solder, OEM GPS is the wrong path for you.
    FLAC edrex's Avatar
    Dec 2004
    Thanks for the input.
    I am definately getting the OEM because of the reviews on them... I will just figure out the soldering I guess.
    Placing my order right now for this one (Price: $79.99): http://www.guaranteedmerchandise.com...L/010-00240-02
    Thanks again.
    New York
    The differences are
    H:
    Input Volt: 8.0 VDC - 40 VDC unregulated (less then 100mV PtP Ripple)
    Output to Antenna: 3.3 VDC
    L:
    Input Volt: 3.3 VDC - 5.4VDC (less then 100mV PtP Ripple)
    Output to Antenna: 3.0 VDC
    Btw, output voltage to antenna is adjustable on certain models. only way to check is via serial number if memory serves me right. all new models should have this feature built in.
    May 2004
    I have three motorola oncore modules, a trimble ACE III module and a Lassen SK2 module and I love all of them. The trimble modules use a lot less power than the motorola ones. I prefer OEM modules because you place the antenna on your roof and you are good to go. Placing the mouse on your roof I'd imagine wouldn't be a good idea if the mouse isn't protected from the environment with a waterproof seal, etc. Also, I'd imagine a long usb cable isn't a good idea either. 25ft of antenna cable is fine. Here is a pic of the interface I built with a LM7805, protection diode and filter cap, as well as MAX232 utilizing both RS232 channels for both serial ports. The button battery is used for the 3V battery backup so it's always a warm or hot start and almanac and ephimeris is retained and a fix can be aquired pretty quickly. This interface should last through cold and hot weather, and both the module and interface can be put in a small case easily if you want. The other unused connector is for connecting a motorola oncore, but either one or the other can be used at one time because they both share the same serial lines. I have no schematic because it's really easy to put together. A 7805, protection diode (1N4001 can be used), and some filter caps. Wire up a MAX232 and a button battery holder and you are good to go.
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by emumanXM
    well, you make it look simple
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    ddn
    ddn is offline
    Dec 2004
    Thats because it IS simple. The MAX232 has hundreds of schematics on the internet, and they are almost all identical because it is a simple device that is generally used for the same things. The 7805 is trivial, just google for 7805 (or 7812 if you want 12V for something) voltage regulator.
    The bad news: Trimble and their distributors are sold out of Lassen SK II's until the end of March. I didn't ask about the Lassen LP (Low-Power) but it could work just as well (if not better). I'll send another email about that.
    ddn
    ddn is offline
    Dec 2004
    Trimble has the LP in stock. I ended up ordering a Motorola OnCore M12+, finding only afterwards they don't support WAAS. Oh well, I'm not impressed with the WAAS improvements anyway.
  1. Replies: 6
    Last Post: 02-04-2006, 10:22 AM
  2. Replies: 13
    Last Post: 02-23-2005, 12:14 AM
  3. General GPS Question
    By Socno24 in forum GPS
    Last Post: 08-30-2004, 05:52 PM
  4. Newbie GPS question
    By devin99 in forum GPS
    Last Post: 08-30-2004, 03:50 PM
  5. GPS question ?
    By Axkicker in forum General Hardware Discussion
    Last Post: 09-06-2000, 02:43 AM
