I would advise that you get the 231 if it will be used on the dash because the xtrak teally helps getting a signal. there is 1 problem though an that is it will turn off after 10mins if no bt signal is detected even if it is being used as a usb mouse so you will have to get the new firmware from holux
LinkBack URL
About LinkBacks
