sounds awesome - keep us updated!
Well i was just down at jaycar for lunch to get my componets for my HUD display (forgot the damn list of things doh) and i saw this kitt for controlling relays by sms.
After buying it $50 later and reading the instructions (gotta build this thing is a monster) I came up with the perfect idea for GPS Tracking.
Now My pc doesn't have a Auto-On feature but with this kitt i can send a sms to the car and turn the PC on.
Then I can send a sms from the PC with the GPS position of the car then i can send a SMS to turn the imoblizer on and keep getting GPS data so i know where the car is.
Now the Datacable for the phone would be going to the PC and the Standalone board.
The pc won't be able to trigger the imobilzer by accident and it's not needed by the PC to turn it on if the pc can't switch on.
So by this method you can turn the PC on get gps position then shut the car down and call the cops yourself.
You can also have input triggers for when you car alarm is triggered etc.
This sounds like a good solution I think what do you guys think?
The kitt is from here:
http://www1.jaycar.com.au/productVie...Max=&SUBCATID=
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Post number 58
Track your car! (free)
For the circuit, pcb and the hex code.
Can control and text back the status of a port. Like ignition on? alarm on?
Thanks thats very handyOriginally Posted by Chris31
The kitt i got has 8 Relays and 4 inputs and you can get it to send a sms when a input is low or high and if a relay is switched on or off so you can get a sms that ignition is on and alarm is on and you could also disable the alarm if you wanted toAlso you can have it not send a sms saying the ignition isn't on but you send a sms to the phone to see if it's on instead of automaticlly tell youg u it'd on or off.
Some 1 smarter than me could make a serial/USB input device so when someone sms's the car it can get the data from the GPS without needed the pc turned on.
that be a smart way as no PC is required and also it be hardwired so even if they broke in and disconnected the battery you would know if it was and you could take action.
Just an idea but I think this could work cause if for some reason the PC can't boot up you have a standalone device to make the car stop which can't be accidently triggered by outsiders unless they know the code to turn the car off.
You can also have a password for accessing the phone.
If it had a GPS input as standard then it be the perfect hardware for us carpc's but for now it can be used with pc on and a GPS logger![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Haha, its been partly done before but never gone public.Originally Posted by NiN^_^NiN
Im redoing it again but much more sophisticated this time![]()
CoolOriginally Posted by Chris31
I like that way cause then it's all standalone and the GPS signal can have a passthrough so the PC connects to the sms module so it can use GPS but not interfere with the actual sms unit.
I'm kinda not looking forward to soldering all this sit lol oh well it's a job that must be done![]()
Still i like being able to remotely turn the pc on and off and stopping the car if it does get stolen even if i can't tell where it is altho lets hope there not smart enough to have it under a huge SLAB of concreat so the mobile can't connect to the nmetwork![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
you'd have to pay for service for two phones for this correct? or am i missing something
PC Components:
My work log
sounds pretty hardcore.. good luck.. hehe.. it's like trying to incorporate 3 devices into 1 system.
imobolizer, pc, mobile phone..
you'll be keeping your telco happy though with all the sms's you'll be making.. haha
maybe you can send a sms to your car and it can sms you back telling you which street it's located in rather than gps co-ordinates from reading the gps software.. that'd be pretty awesome. if you work it out post some pics of your setup so i can have a look. cheers
CAR INFO HERE
"He who dies with the most toys, wins".
Well im not sure im gonna see if i can get a copy of my sim so i send the sms to myself and the i will get it so will the car phone altho it get the same sms i did so i'm not sure![]()
There should be plans out there for this kind of thing im sure![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
The GPS is shared between the tracker device and the PC, as well as the mobile phone is being shared.
Oh you can also activate the drivers eject seat if you want it to by sending a txt.
