Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: GPS for LCDs
  1. #11
    Variable Bitrate Saab9-5's Avatar
    Mar 2005
    Ponta Delgada, Azores
    Quote Originally Posted by tj!2k4
    having super teriffic engrish for happy gps
    Quote Originally Posted by Tx_Cat
    I have a Pioneer 7" LCD. Will any USB GPS receiver work?
    No. No way. Definitely not.
    Tx_Cat / djkl407 - You're not going to be able to buy any cheap GPS and connect it directly to your LCD monitors. The reason they're so cheap is that the processing is done with a computer rather than built in. This device - http://www.icircuits.com/prod_geostampplus.html - will overlay the GPS data from a serial GPS receiver onto a video signal. But then, that information isn't really useful since you want to see maps/streets and have it guide you to your destination, right? For that you need processing power, either in the form of a PC, a PDA with an optional video out adapter or a standalone GPS navigation system. Any of those three are going to cost you some money.
  2. #12
    Elsewhere
    You need a few things to make GPS funtional, be it at home or in your car:
    The receiver
    This is what receives the signal from the satellites about your position. Most of these are a little smaller than a computer mouse. There are aftermarket GPS receivers that have a more OEM look, like the fintenna on BMWs for example.
    Interpreter software/map data
    You could have an interpreter wihtout map data, but that would only result in your ability to get latitude and longitude. Most people can't interpret their position from only lat & long, so the map data is crucial for plotting your position.
    Standalone Garmin units (at least the lower-end ones) go strictly by latitude and longitude. You can set waypoints to find your way around. Say you're going hiking in the woods. You park your car and set a waypoint at your car, so no matter how deep into the woods you go, you can find your way back to your car (assuming you don't get eaten by a mountain lion). This isn't going to tell you if there's obstacles in your path, only the direction from your current position to your waypoint.
    Navigation software
    This is what you want in a vehicle. The map data for nav software includes streets, roads, highways, byways and nondescript goat paths. They follow basic driving rules such as driving on the streets only (so you don't drive through the lobby of an office building). The road map data also includes one-way streets and categorizes roads (Freeways, major streets, etc.) to optimize the routes.
    Basically the navigation software plots addresses and determines the driving route between the two addresses. They will give you turn-by-turn directions from the starting waypoint to the ending waypoint. Many software for vehicles will also speak the directions to you, saving you from having to look at a map while driving. It knows when you're approaching your turn based on your current position from the GPS data.
    Output
    Usually a vide screen of some sort. directions can also be printed on a printer, for computer-based GPS software.
    For those of you with a screen, you can't get a $39.99 GPS receiver. You'd only have the the first and the last of the elements necessary.
    I hope this clears up some questions for other n00bs as well.
    How about the Wiki?
  3. #13
    Feb 2005
    El Paso, TX
    Well, Im putting a pc in my car(PIII 600 512ram) and using my Pio LCD as monitor, I was referring to that!!! Darque, thanks for the well informed view man.. I really learned. I first need to make my stupid LCD to work with my PC (having setting issues with vide card) then I'll worry about putting GPS on my car
  4. #14
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    This should be an interesting project. I for one would love to see the results of adding this Pioneer LCD to a PIII motherboard....
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
  5. #15
    Feb 2005
    El Paso, TX
    Well it works believe it or not. Thanks to cold fusion it works. I see the bios, when windows is loading and I get to windows, my only problem is to get rid of the lines that go down over and over and over again. I set my resolution and refresh rate low and I still get the lines.
    djkl, sorry for hijaking ya thread man I did asked about GPS tho!!!
  6. #16
    Newbie MICK UK's Avatar
    Dec 2005
    Spain
    Newbie Q.
    Can I get pc sofware for Teleatlas/Navteq map discs for the Carputer?
    Does the VDO software work in a PC?
    Carputer Progress: [----*------]
    Hardware: [---*-------]
    Softwarre: [------*----]
    Design: [Complete]
    Finance: [In Progress, multi items on Ebay]
    Fabbing: [Design complete, Assistance sought]
    My project page
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  2. OEM GPS mod. Writeup + Pics
    By IntellaWorks in forum Hardware Development
    Last Post: 07-04-2006, 03:59 AM
  3. My GPS scenario & Bluetooth quest.
    By gizak in forum GPS
    Last Post: 04-12-2005, 01:11 PM
  4. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
  5. Newbie's guide
    By EBFoxbat in forum Newbie
    Last Post: 02-08-2005, 11:06 AM
