Results 1 to 9 of 9
Thread: No Sat Lock Inside Car With Rikaline 6010 Gps
    Feb 2005
    i get no sat locks when my RIKALINE 6010 is postioned inside my car (vw golf mkiv), no matter what location i put it . i get at best two red signals . when i put the RIKALINE 6010 on the roof outside i get atlest 8 green locks, move it inside and they all go, untill the nice lady tells me signal too low ( d3 )
    i have tried sirf mode , removing the battery and tin foil but all have no effect. any tips would be great . does any one know where the golf mkiv have there factory fitted receivers postioned ?
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Make sure that you're facing the top (the side with the LED) of the receiver towards the sky when mounting inside the vehicle. It works best if it has a clear view of the sky too; so through clear glass helps. Tint with metallic content can cause reception issues also.
    Mine is on the inside of my tinted rear hatch glass and I get anywhere from 6 to 9 sats.
    Feb 2005
    have tried all windows and even with windows and boot open with the Rikaline 6010 looking stright up to the sky with no locks, take it out of the open boot and on the roof , all sats come back. i see that other vw golf/bora owners have there set ups working just fine. my golf is bog standard 1.6 se, so why me with the problems . i guess the only way to to see whats going on is to get a second recevier and test that one .
    Maximum Bitrate DeltaFX's Avatar
    France
    Do your car windows have a slight purple tint sometimes ? It looks like you have Anti-IR coating (Titane's nano particules) that block radio waves.
    Feb 2005
    got it working . got hold of a usb extension cable and postioned the mouse right under the front windscreen. seems to like that and now get 2-3 locks inside car. still takes a wile to lock ( 5 minutes) but at least i can now use it . thanks for help
    Constant Bitrate TaylorMade's Avatar
    Nov 2003
    Tampa, FL
    wow. I had the same problem with the earthmate inside my vehicles. no matter where I put them, it never got more than two or three sats. I went to the rikaline specifically so I could put it on the roof (magnetic and weatherproof) and i get locks as fast as I can start the GPS applications. I'm talking full on 8 or 9 sat locks. VERY pleased with the investment.
    2008 Ford Expedition EL Ltd
    Carputer yanked from the Jeep and Denali and waiting to be installed in the Ford.
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    What are you using to determine the number of sat locks you are getting?
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    Constant Bitrate sanbas's Avatar
    Jul 2004
    united states
    i am using the rikaline 6010 with iguidance 2.1 here is what worked best for me on a 4 door sedan.
    If i place the receiver on the top of the trunk i got 8+ locks everytime (but then i would have to open the trunk and put it back inside evertime i left the car so someone doesnt just go and cut the cable off)
    So i put it inside the rear window (my car has a pretty dark tint), this resulted in 4 or less locks usually 3. It worked fine, but i wanted to have more sat. locks if i could get it.
    So...i put it in the section of the rear brake light, where the window doesnt have a tint and it consistenly get 7+ satallite locks...works great!
    Moral, window tint and/or rearwindow defrost wires can reduce the satallite locks GREATLY!!!
    FLAC -zip-'s Avatar
    Ontario/Canada
    My 6010 is under the dash behind the gage cluster that the driver looks at. Getting 4-7 sats. There is no tint on a front windshield and it is completely out of view.
    Is there a spot behind your gauge cluster to place it? there is only a piece of plastic, then the front windshield.
    Depending on the rake of the windshield if you tuck it in deep it has a clear view to the sky.
    Took a little of fidgeting to get it right, it went from 0 sats to 4-7 just by moving it an inch.
    Sound Stage
    Eclipse|MTX|Infinity
  1. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
  2. Rikaline gps led not blinking
    By vipergda in forum GPS
    Last Post: 02-28-2005, 11:28 PM
  3. My new car, pic inside
    By lstrunk in forum Off Topic
    Last Post: 07-13-2002, 10:59 AM
  4. GPS in my car - Newbie
    By hasato in forum General Hardware Discussion
    Last Post: 01-29-2002, 09:11 AM
  5. bringing the inverter inside the car
    By dizzzyduck in forum General Hardware Discussion
    Last Post: 07-08-2000, 05:04 PM
