Results 1 to 6 of 6
Thread: Proper Installation of GPS Receiver
    Oct 2004
    I've searched only to find a little bit of info regarding this. It'll prolly be a good sticky for us newbs.
    Anyways, I got myself a holux gm-210 (USB) unit and plugged it into my carputer. And then installed Iguidance. No luck. Forgot the drivers, duh.
    Okay now I installed the drivers and used the GPS utility that tells you some stats and info. Cool... I go to startup Iguidance and nothing.
    Alright... i figured I'd restart, and now everything's working great. Cool. I move the unit inside the car on my rear dash (its near speakers and factory amp... does that affect it?). And nothing.
    So then I the next day I take a shot at it (and move the unit back on my roof) and now nothing. Iguidance recognizes where the GPS is located (com3 for me), but it doesn't pick up any satellites.
    I checked device hardware and I've got an exclamation mark on a "Mouse Serial" something. But right below that is the "Holux GPS Receiver"
    Could that have anything to do with it?
    So with that long story out of the way... can anyone provide tips and steps on a proper GPS system installation?
    Here's a start from what I've gathered:
    -always install the drive WITHOUT the unit plugged in
    -restart the computer and then plug in the GPS unit
    -test the unit with a GPS utility program and take note of what com port the unit is located
    -install GPS software and point it to the correct com port.
    Thats all i've got so far and am still trying to get mine working properly.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    disable the serial mouse
    Feb 2005
    New Orleans, LA
    My system crashed once and I had touble reinstalling my GPS. Basically I tried again and again (uninstall then reinstall) and eventually it worked. Not sure what happend it just eventually started working. Since then I have had no trouble with it...haven't messed with it at all and it works like a charm. I was also having issues with the virtual serial port as I was using a USB Earthmate, but like I said it eventually resolved itself.
    1997 VW Jetta GLX VR6
    old HP MP
    PIII 600 or so 256 MB
    7" Xenarc
    and some plywood holding it all together
    My Project
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    my earthmate did that a few times i just uninstalled all the drivers and stuff and reinstalled it all worked fine try it out tell us whats up
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    & once you get it all back together.. take a look at iGuidance GPS info to see if it's streaming NMEA data. Your TimeToFirstFix TTFF may be a good minute or two if you're waiting for the green arrow to just pop up.
    My first frustration w/ GPS was that I wasn't patient enough.
    Good luck w/ it
    •Micke
    Oct 2004
    okay... i'll uninstall the device first.... then reinstall... and if that mouse serial device pops up again i'll disable it... then i'll check with iguidance's info on that NMEA data
  1. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
  2. GPS receiver noise
    By Sh0cker in forum GPS
    Last Post: 07-01-2004, 10:10 PM
  3. WTB: GPS receiver (USB)
    By Mastero in forum Classified Archive
    Last Post: 06-18-2004, 12:25 PM
  4. Fs: 12 Channel Usb Gps Receiver
    By Motorcity in forum Classified Archive
    Last Post: 04-27-2004, 08:08 PM
  5. WTB: USB GPS receiver
    By Toups in forum Classified Archive
    Last Post: 04-26-2004, 11:37 AM
