Results 1 to 10 of 13
Thread: What can cause radio interference with GPS signals?
    Low Bitrate chilli_pepper's Avatar
    Aug 2004
    Midlands, UK
    Ok guys,
    Heres the senario...I have been using a BU-303 for a few months hooked up to a laptop and sitting on my dash with MapMonkey for long and new journeys. The signal was 90% locked with it sitting on my dash which i was pleased with.
    So I have now installed the car PC with an Opus run leads upto the front for a Xenarc and a usb hub/extension. The Gps is mounted in exactly the same place as it always has been but now wont lock...or many/any signals for the majority of the time.
    Shove it on the roof....instantly locks with 6-8 sats.
    Its really ****ing me off as it was all working so my feeling is something that i have installed must be interfering with the reciever unit itself.
    So what i am asking is what could there be that i have instaleld that interfers with the GPS signals in the car?
    I have extensively tested the reciever and it is working great, it does the same thing connected to a dedicated port, the hub or an extension and i have tried changing the position within the car and it makes no difference!
    Please help me
    Chilli_P
    Epia 800 > 3.5" 30GB HD > Teac Slim CD > BU-303 GPS > Safecom Bluetooth > WiFi > Xenarc 700TSV > Opus 150
    Current Status:Installed - tweaking
    Want Widcomm 4?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    RF interference from the PC or the power supply. I had an identical experience to yours. I picked out a nice spot on the rear shelf for the GPS, tested it with the laptop and it worked perfectly, always at least 7 sats and often more.
    Installed the PC underneath the shelf. No lock. Didn't work. Had to move the GPS to the front of the car. Found out that when I swapped the screen to a Xenarc, it also interfered with the GPS signal!
    Basically, anything in the 1.1 ghz band can potentially intefere with the GPS receiver.
    Want to:
    Aug 2004
    Midlands, UK
    Well
    I have a Xenarc...and as the car is soooo small i cant really get the reciever anywhere more than 1.5 meters (if that more like 1 meter) away from any of it...and if its away from the pc+psu then its near the xenarc!
    Nightmare!
    What are my options? could i wrap the pc and powersupply in foil or something like that?
    How have u sloved your problem if you pc is in the back and screen in the front?
    Cheers
    Chilli_P
    Want Widcomm 4?
    Dec 2004
    QLD, Australia
    Im having a similar problem in another thread, using a Xenarc and a Garmin GPS mouse split from the same 12v plug; not that that should matter :/
    Garmin GPS18PC causing the mouse pointer to act strange
    Rode-B[O]X: scrounging components
    Bits I bought:
    Xenarc 700TSV | DSSC | GPS18PC
    Pieces Im looking at:
    Axus TC600 WINXPe | EPIA * | GPS gadgets
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Haven't really solved it. The GPS is about a foot away from the Xenarc. It gets intermittent reception. Never loses the lock for a real long time so I just put up with it.
    My PC doesn't have a case. It would probably help if I put it inside a metal casing.
    Want to:
    Low Bitrate phord's Avatar
    May 2004
    No case on my PC. I mounted my Earthmate GPSr inside the dash behind my Lilliput and I always got an excellent lock.
    Then I got a USB GPS mouse because StreetAtlas sucks in a car... and it wouldn't lock unless I held it just right against the glass. Sometimes it worked ok, but usually it showed pretty weak signals. If I put it on top of the car it immediately gets 100% signals from all sats.
    So I punted. I pulled the USB wire through the firewall of the car and put the receiver (magentic mount, doncha know ) on the hood by the windshield.
    Carputer-II: Infiniti Q45
    Simple setup, NAV-only
    Tablet PC :: FP :: iGuidance
    Status: Ghetto, baby!
    Carputer-I: '99 Honda Odyssey
    Dual monitor, separate outputs: Finished
    FP :: iGuidance :: WinDVD :: EPIA M-10000 :: Opus 150w :: In-dash/On-dash
    Aug 2004
    Midlands, UK
    My PC is in a wooden box, and under the rear seat the Opus is next to it.
    Is there anyway i can screen them? Would wrapping in foil be a waste of time?
    Chilli_P
    Want Widcomm 4?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Tint can interfere with radio signals.
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    As boris said, I found my tinted windscreen contained a metallic film which blocked over half of the GPS signal. But my sunroof didn't so I placed the receiver on top of the sunroof blind under the glass, only thing was, when the roof openned you had to grab the receiver and stick it out on the roof before it got swallowed into the roof cavity
    The GPS receivers also work better with a small piece of sheet metal under them. Mine sits on a 6"square piece of 1mm thick mild steel plate and regularly picks up 8-10sats.
    HTH
    Aug 2004
    Midlands, UK
    Decided to waterproof it and throw it on the windscreen scuttle!
    Works now
    Chilli_P
    Want Widcomm 4?
  1. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  2. Using Radio Antenna for GPS
    By phita23 in forum Newbie
    Last Post: 03-27-2005, 12:42 PM
  3. Supported GPS and Radio ?
    By killervince in forum MediaCar
    Last Post: 02-15-2005, 02:24 PM
  4. TM-701L converted Lilliput causes radio interference
    By archimense in forum LCD/Display
    Last Post: 07-04-2004, 08:14 AM
  5. GPS Radio
    By Cmage in forum GPS
    Last Post: 03-30-2004, 04:30 PM
