Results 1 to 10 of 20
Thread: problems with gps when startup...
    Aug 2004
    Denmark
    When i turn on my carpc and start MM, It wont find any sattelites. Then i run the Sirf program and press "connect. Then i press "synchronize baud....."
    and on the viewer i see 9-10 sat. Then i open MM again and now its working.
    So i restart my carpc and start MM again, and it works. I did that 3 times the same day and it worked.
    Then the next day (12 hours later), MM cant find any sattelites again and i have to do the same again with Sirf prog. aso. So strange!!
    My gps. conf. in MM is ok.
    Anyone know what the problem is?
    sorry about my bad english.
    P4.1,8 - 512 ram - Power: M1-ATX 6-24V DC/DC - HU: Blaupunkt Seattle MP74 - Lcd: lilliput touch. - GPS rec. Navilock NL-202U ( USB).- 2 usb for ex. - 1 cardread. 9 in 1. - Softw.: MapMonkey - Frontend: Roadrunner
    Super Moderator xBrady's Avatar
    USA
    Common issue that all GPS software has to deal with (hibernating). I thought MM accounted for that problem though. I might be wrong as I haven't had it in my car for a long time.
    Installed.
    -GPSSecure- - GPS Tracking
    Jan 2004
    Jersey/NY
    the only thing off of the top of my head is... is your gps being powered when the computer is off?
    Since you turn off the computer overnight, it can lose all of it's backup battery, and maybe it just takes a really long time to re-aquire satellites.
    Where if you turn off computer for only a short time, the capacitor or whatever reserve battery is in the gps unit has enough power to help the gps unit remember where it is while the computer is off.
    Aug 2004
    Denmark
    Quote Originally Posted by xBrady
    Okay...And how do i fix it? And what is hibernating?
    USA
    Quote Originally Posted by yokeren
    Well I might be wrong about your problem if you aren't putting your computer into standby or hibernation.
    Installed.
    Aug 2004
    Denmark
    When i shut down i just cut the power in desktop. Not closing windows..but it shoudent be a problem.
    I can wait 3 hours and turn it on and it works. But not a day..is it about warm and cold start for the gps?
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    After leaving it off overnight, connect to it using hyperterminal at 4800 baud and see what happens.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Aug 2004
    Denmark
    Quote Originally Posted by stevieg
    in sirf or Nmea?
    Aug 2003
    Warwickshire, UK
    in sirf or Nmea?
    without changing ANYTHING, it would help me tell you whats wrong if you can tell me what it does if you connect to it at 4800 baud with hyperterm, before you 'fix' it.
    Also if don't get $GPRMC,00093,873763,23984884 kind of stuff try again at 9600 and also let me know.
    Aug 2004
    Denmark
    okay.. what is " hyperterminal", dont get it??
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 05:54 AM
  2. Problems with MM Advanced Mode/SiRF
    By RoyN in forum Map Monkey
    Last Post: 04-24-2005, 11:49 AM
  3. Error message on Gps with frodo & guidance
    By biglips31 in forum GPS
    Last Post: 01-27-2005, 10:13 AM
  4. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 01:54 PM
  5. Replies: 9
    Last Post: 10-25-2004, 01:34 AM
