Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: RG 174 cable with SMB female connector to USB
  1. #11
    Apr 2005
    Quote Originally Posted by Scouse Monkey
    hell yeah!!
    you can build an oem type system with separate antenna for a about 33 (module) and 14 (antenna). That works out cheaper than a BU-303!!!
    but quite frankly, DR is where it's at!
    And how would I go about building this OEM type system? Any links to websites or anything? I can get the antenna no problem...
  2. #12
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    肚子笑痛了
    S60 Install
  3. #13
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by stewrockka2
    have you ed?????
    you can find some info on this forum (search for OEM modules)
    if you re-read my previous post i did say you may need to make USB or serial interfaces (i prefer serial) or RF solutions may do a ready made unit for cheap.
    i onyl started looking at GPS systems 2 days ago and I am already working on a dead reckoning system - it's not hard to learn. But you need to read. Start with the OEM GPS threads on here and then go look at some hardware on manufacturers sites. I can't be much help i am afraid as I am new to it and might advise you wrong. I am jumping strraight into the deep end as no one on here has done a DR system before. it has been discussed but not done. Even my avionics lecturers at work were amazed it could be done so easy when i asked them for advice.
  4. #14
    Mar 2004
    Bristol
    Those are were we are looking but if you are not very confident with electronics and want soemthign cheap and easy then look for a system with the outputs on and the battery backup already one.
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. USB video input cable
    By Custommx3 in forum Input Devices
    Last Post: 05-04-2004, 02:51 PM
  3. where can i find a USB cable like this one?
    By jusatry in forum General Hardware Discussion
    Last Post: 04-11-2004, 04:24 AM
  4. Lilliput USB cable
    By Custommx3 in forum LCD/Display
    Last Post: 03-20-2004, 07:12 AM
  5. USB gps mouse , max lenght cable
    By BOND007BE in forum General Hardware Discussion
    Last Post: 12-17-2003, 07:54 PM
